Headlight Electrical Help
Old Jan 12, 2021 | 11:12 PM
corvette8189's Avatar
corvette8189
Default Headlight Electrical Help
2000 Vert
All lights work but the headlights won’t go up or down. They just stay up. I’ve checked all fuses. I’ve tried swapping out the switch with no change.
I tested the module and I’m not getting 12v at the dark green wire.
where does this wire go?
Any help is appreciated.
Old Jan 13, 2021 | 04:10 PM
corvette8189
Bump
Old Jan 13, 2021 | 05:18 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
From my 01 FSM !!
Old Jan 13, 2021 | 07:13 PM
corvette8189
Originally Posted by C5 Diag
From my 01 FSM !!
SO that wires goes through the fuse block to the BCM and headlight switch.
So I wonder where it gets it 12V from and where I should look? I assume the 12V makes it shut as I've tested the motors and they work fine. I disconnected the battery and hooked it back up and they went back up, and wont go down. SO my issues is they wont go down.
Fixed problem the connection at the fuse box was bad. had to pull apart fuse box and cut the wires and splice them together since its just a pass through and they work fine now.
To Headlight Electrical Help
