Timing Crank Torquing
Old Jan 13, 2021 | 02:56 PM
b_907's Avatar
b_907
Default Timing Crank Torquing
I am swapping the oil pump on my engine with it still in the car, so I decided to swap timing gear while I was there. I purchased the Cloyes Race Billet True Roller Timing Set 9-3658TX3, to install, I am using the old sprocket and the crank bolt but it seems tight. The crank is turning while i am trying to press it on with the above mentioned method, is this normal? Should I be concerned? Can I just complete the rotation to get it back in time, or is it not 1-1 turns?
Old Jan 13, 2021 | 03:58 PM
Smoken1's Avatar
Smoken1
Auto or M6 car? BTW you need to replace the crank bolt
Old Jan 13, 2021 | 04:00 PM
b_907's Avatar
b_907
M6, already got the new bolt ready when we get to that point, thanks for the reminder!
Old Jan 13, 2021 | 04:09 PM
Smoken1's Avatar
Smoken1
Did you put it in 6th gear and use the e brake that should stop it from turning
Old Jan 13, 2021 | 04:12 PM
b_907's Avatar
b_907
The E brake is set and I left it in 1st, do you think that would stop it?
Old Jan 13, 2021 | 04:57 PM
Smoken1's Avatar
Smoken1
I have seen posts where that method works. Mine is a auto so I needed this tool and it should work on your car also
Amazon Amazon
Old Jan 13, 2021 | 04:58 PM
MetalMan2's Avatar
MetalMan2
Needs to be a higher gear. In 1st the e-brake can't counter-hold enough torque to prevent the crank from turning. The higher the gear, the higher the torque the e-brake imparts on the crankshaft.
Old Jan 14, 2021 | 07:30 AM
CinciZ06's Avatar
CinciZ06
I’ve done the e-brake / 6th gear / rear wheels on the ground method numerous times and it works perfect. It will hold 250 ft lbs no problem.
Old Jan 15, 2021 | 10:33 AM
Gordy M's Avatar
Gordy M
The only time you might run into a problem with a manuel in 6th gear and e-brake is if you are putting in a stock crank bolt. When tightening the bolt from the 37lb torque another 240 degrees you can often exceed 300 ft-lbs of torque and the crank will turn. Then you have to lock the flywheel. That is why most will use the aftermarket crank bolt.
Old Jan 16, 2021 | 08:18 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
But I like to be fully prepared, when tackling a job of that magnitude, so when I replaced my HB and timing chain, I purchased the crankshaft locking tool. The only "issue" with it, is that you have to remove the starter, in order to secure it in place.
Old Jan 16, 2021 | 08:39 AM
2003_Coupe's Avatar
2003_Coupe
Banned Scam/Spammer
I bought one of these too. Its only about 15 dollars on ebay and its guaranteed to keep the engine from turning.
Old Jan 16, 2021 | 02:25 PM
grinder11's Avatar
grinder11
I'll probably take a lot of heat for what I'm going to say , but here goes......I have a 2000 A4 Vert, so I have no 6th gear. I've had my balancer off, and back on, my current LS7, and a different engine that was in it previously, at least 3 times on each engine. The balancer bolt, at least an ARP bolt, will end the nonsense of torquing and a special torque angle gauge, or 6th gear torquing, etc. I have used only my 1/2" air impact, set at max torque. You're looking at threads so large, they would be hard to almost impossible to strip, unless maybe using an "Earthquake" impact. My balancer has never slipped, come loose, and I have never come close to stripping these threads. It works, and continues to work, for me. But hey, do what you're comfortable with. I can't guarantee anything for anyone. Sure, hook up a 3/4" drive impact with 1,100 ft/lbs of torque, your probably gonna have trouble. Just my 2 cents......
To Timing Crank Torquing
