Emissions test did weird things
Old Jan 14, 2021 | 10:58 AM
Forgetful's Avatar
Forgetful
Default Emissions test did weird things
I got my 99 emissions tested today. Test consisted of me starting the car for them, then while it was running they plugged into the OBD2 port and took the gas cap off to check it.
Once I got back in my car I noticed the Security light was illuminated on the dash and the clock had been reset to 1:00.
One I turned the car off and back on the security light went away clock was still off.
Anything to worry about? I've already had to replace the entire cluster due to electrical gremlins in it.
Old Jan 14, 2021 | 03:13 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Plugging into the DLC should have nothing to do with your security light and clock...what “gremlins” did you have that you had to replace IPC ??...I’d reset your clock and drive on !!
Old Jan 14, 2021 | 03:14 PM
visvette's Avatar
visvette
Sorry to hear. Always frustrating when someone else messes with you car. I haven't experienced this on my Vette but I had a similar thing happen on my E36 BMW. Turned out the fuse running the clock and climate control blew. Seems like your clock is working so I doubt a fuse blew but it does sound like something temporarily lost power and came back.
Do you have an OBD scanner? If so, try plugging it in and see if it still communicates with the car. Also would be a good idea to check the fuse that runs the OBD port. If I remember correctly, it usually shares power with the aux power (cigarette lighter). If you have no power going to the aux power then a fuse probably blew.
Old Jan 14, 2021 | 03:38 PM
Forgetful's Avatar
Forgetful
I'll poke around with the fuses.
The previous IPC issues I experienced was RPM gauge died, DIC screen was cycling like crazy though options, seatbelt chime was extra loud and constant, something else that escapes my mind.. Not all started at the same time.
Old Jan 15, 2021 | 05:32 AM
dmsog's Avatar
dmsog
....four posts and nary a hint of a suggestion to sue the emissions testing place? You guys are slipping.
Old Jan 15, 2021 | 04:41 PM
Speedy007's Avatar
Speedy007
Weird never had them take off my gas cap during a test it was a simple scan of Monitor readiness and that’s was all ....
Old Jan 16, 2021 | 04:38 PM
ncali's Avatar
ncali
they have to remove the gas cap to pressurize the fuel system
Old Jan 16, 2021 | 05:25 PM
Speedy007's Avatar
Speedy007
That monitor doesn’t have to be ready in California most states allow up to 2 not ready there was not reason for them to touch it .
Old Jan 16, 2021 | 07:11 PM
3sACROWD's Avatar
3sACROWD
Your issue could be unrelated to the testing. Before going too far, verify your battery is good by having it load tested.
Old Jan 16, 2021 | 09:38 PM
MetalMan2's Avatar
MetalMan2
I've never had a CA smog test where they didn't check the gas cap itself... and believe me I pay a lot of attention during smog tests because my vehicles have been "questionable".
Old Jan 17, 2021 | 11:10 AM
Speedy007's Avatar
Speedy007
Ya but when u pull up with off road mods clearly showing I guess maybe they tend to turn a blind eye I would .....long as it passed the scanner here ya go have a good one ....
Old Jan 23, 2021 | 07:47 AM
eric22's Avatar
eric22
For what?!
Old Jan 23, 2021 | 07:49 AM
eric22's Avatar
eric22
Every state is different. Some states even have emissions testing only in part of the state!
To Emissions test did weird things
