Brake related question
Old Jan 16, 2021 | 11:27 AM
Geotechengr's Avatar
Geotechengr
5th Gear
Default Brake related question
Hi - I have a 2004 base Corvette. Installed new brake system and bled the lines but still have air. Can someone tell me if the ABS module has to be bled also? It is stock unit to my knowledge.
Thx
Ron
Old Jan 16, 2021 | 11:40 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
I pressure bled my brakes when I installed a new system years ago...never had to cycle the ABS.
Old Jan 16, 2021 | 11:43 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
You're meant to cycle the ABS when you bleed, but sometimes you get lucky and get away without it.
Old Jan 16, 2021 | 11:47 AM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
If you got air in the ABS pump then yes it will need to be bled out and likely need to be cycled to get it out. You can do this with a Tech 2 computer or you can do it the redneck way by bleeding the brakes as best you can and then drive the car to a slick piece of road and lock the brakes up enough to activate the pump. Then rebleed the system and you should be good to go.
I also prefer pressure bleeding but that's just me. The old school way works too.
Base or not C5 brake systems are the same across all.
Old Jan 16, 2021 | 12:11 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
This issue concerns me, too, as my C-5 is getting close to 20 years of age, and I know that brake lines don't last forever. Therefore, I see myself replacing them within the next year or two, and having to bleed the lines.
Old Jan 16, 2021 | 12:14 PM
Stingroo's Avatar
Stingroo
Wasn't a big deal for me to bleed it the old school way and drive it to work the next day with a semi-soft pedal and have work bleed it with the tech 2. Any GM dealer will be able to do it.
Old Jan 16, 2021 | 12:18 PM
Mr. Black's Avatar
Mr. Black
Another pro tip, if you do manual old school brake bleeding, and you live in a corrosive environment I recommend not pumping the pedal all the way to the floor. Doing this can run the master cylinder seals through trash and ruin the master.
I've done it twice in my life and after the second failure I switched over to pressure bleeding.
Old Jan 16, 2021 | 07:08 PM
Geotechengr
5th Gear
thanks for advice. I have a MaxiCheck by Autel but read somewhere that the C5 pump can not be bled. True?
Old Jan 16, 2021 | 07:36 PM
Mr. Black's Avatar
Mr. Black
To the best of my knowledge any ABS pump can be bled by cycling it with air free fluid from above. I'm not familiar with Maxicheck but like I said if you have enough brakes to drive it I would just go lock them up.
Is the pedal soft? Can you pump the brakes up at all? or is it all the way to the floor?
Old Jan 16, 2021 | 08:33 PM
Stingroo's Avatar
Stingroo
False. The FSM has a procedure to bleed the pump. Taken straight from my 2002 manual:
Old Jan 17, 2021 | 02:34 AM
Moving over to C5 Tech.
Old Jan 17, 2021 | 07:55 AM
Adwest52's Avatar
Adwest52
2021 C5 of the Year Finalist - Unmodified
When you say you installed a new brake system did you just install new calipers or did you replace the master cylinder or any brake lines?
Old Jan 17, 2021 | 09:50 AM
Geotechengr
5th Gear
Thanks Mr. Black and Adwest52. I changed pads, rotors, calipers, and hoses. Used all Wilwood products. Calipers are fixed not sliding. Pedal goes to near floorboard but does engage and stops vehicle in solid/firm manner. However with slight pump the brakes engage much higher.
Geotechengr
Old Jan 17, 2021 | 02:01 PM
Smoken1's Avatar
Smoken1
Are the bleed screws at the top or the bottom? I have seen ppl put the calipers on the wrong side
To Brake related question
