Safe Operating Temperature
Old Jan 19, 2021 | 09:48 PM
Townicus's Avatar
Townicus
Default Safe Operating Temperature
Good day to you all!
Relatively new C5 Z06 owner. Building car for NASA TT. A few general cooling questions.
First of all, the car has a custom cam; FAST intake; LS2 Throttle Body; ATI damper; CAI; Headers; exhaust; RPM Tranny and Diff.
The car is making 422 whp...
I performed a practice session at my local track; 50 degrees, 7500 ft of altitude (Colorado). Ran laps for about 5-10 minutes.
Before I go into the modification rabbit hole of spending unnecessary money, what are safe temperatures for water and oil?
I saw water temps around 235, oil temps around 265-270 before I decided to back off.
I got a tranny temp warning?
I’m getting a cage, seats, harness, and a tune for starters...
Thanks!
Old Jan 19, 2021 | 10:53 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
235 is about as high as I would be comfortable with my water temperature to be at. I’m surprised it got that warm at 50 degrees ambient temperature though.
Old Jan 19, 2021 | 11:08 PM
Townicus's Avatar
Townicus
FYI, driving down the highway at cruising speeds, oil temps sits at 225 degrees all day; water temps 192...
Old Jan 19, 2021 | 11:16 PM
rjacobs's Avatar
rjacobs
If I was mainly tracking a car it would FOR SURE have a Dewitts radiator(straight radiator, no additional coolers built in) in it AND a Lingenfelter oil cooler. The lingenfelter cooler mounts to the cradle and not in front of the radiator.
I would also likely run a Big Mouth performance air dam to really ram the air into the radiator...
Then I would run some type of hood vent in order to get the heat out...
Old Jan 19, 2021 | 11:18 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
235 won’t hurt anything, if that’s as high as it gets.
I’m just a street driver though.
You may want to check with the guys in the Autocross and Road racing forum and see what their advice is.
Old Jan 19, 2021 | 11:25 PM
Kingtal0n's Avatar
Kingtal0n
For GASOLINE applications with medium(9-10) compression ratio in NON-forced induction racing applications at 100KPA (1 bar of atmosphere)
The ideal water temp range is 206*F to 217*F , oil 210*F-224*F
IAT less than 110*F
Basically keep your engine coolant fluids(oil water) near the boiling point of water for 1atm, and try to keep the oil temp low and near water temp.
Engine oil is designed to work best when fully warm and the 205-210*F oil temp range is a minimum safe recommended temp.
Old Jan 20, 2021 | 11:27 AM
Moved to C5 Tech.
Old Jan 20, 2021 | 12:39 PM
NewFoundPower's Avatar
NewFoundPower
That sounds about right for both, but a little surprising they're that high with ambient temp at 50. I've seen very similar fluid temps but with ambient in the 90 degree range.
I added an oil cooler and saw around 250 at the track last time (September in Houston).
Old Jan 20, 2021 | 03:05 PM
grinder11's Avatar
grinder11
I agree with temps being pretty warm for 50° ambient. OP, do you have the stock radiator? I also agree on the DeWitts. You may find a good, cheaper radiator, but you won't find a better one. I've had one for 15 years now, cooling a 427, and with a 160° Stat, and a 25% underdrive balancer, I rarely see 200° running 80mph down I-75 in Florida in 85° temps. Sometimes hits 210° running up to around 140mph on a lonely section of freeway! It's also an A4, and I do have a trans cooler, but the radiator is also helping cool the trans. On my dyno tune, the dyno operator said it never got over 190°, fwiw. Hope this helps......
Old Jan 20, 2021 | 04:43 PM
TrackAire's Avatar
TrackAire
For 50 degrees I think the water temps are too high....7500' elevation doesn't help either. The problem is you'll be at 260 degrees water temps on a 80 degree summer day.
I would definitely would check the following first:
1. Is the bottom air dam scoop in place to direct airflow to the cooling stack?
2. Is the A/C condenser and radiator clean? I get at least a quarter cup of sand and debris out of the two of them after just one track day and I don't street drive the car....all track miles.
3. Make sure the air flow is going through the radiator stack and not getting pushed out the sides and around the stack.
4. Double check your tune to make sure you're not running lean...I would think going on the rich side may cost a couple of hp but drop the temps at least 10 degrees
5. Maybe look into doing a coolant cross over on the rear cylinders to help balance out some of the temps and flow.
These are minimal cost things to try first before you go to an aftermarket radiator, etc. Regardless of the radiator, it can only cool if air flow is going through it to dissipate the BTU's so make sure the system is getting air in and out of the radiator.
Good luck!!
Old Jan 20, 2021 | 06:44 PM
heggsc5's Avatar
heggsc5
Good luck!!
From the factory, the high fans are set to come on at 235, so I wouldn't necessarily worry about hitting 235...but I agree on things changing once ambient temp are higher. Definitely check the health of your cooling system before "upgrading", by doing the things mentioned above. Also for consideration before moving to a larger radiator is correctly installing a set of Trackspec hood vents. Cheaper than a Dewitt's radiator and will help front end lift as well as cooling, but hood vents may or may not be your thing.
To Safe Operating Temperature
