Need help identifying these sway bars
Old Jan 23, 2021 | 01:10 AM
OneBadBanana's Avatar
OneBadBanana
Default Need help identifying these sway bars
Guy said front sways are 33mm and rear sways are 24mm. From my searching - the fronts closely resemble the C6 ZR1 and the rears closely resemble the C5 Z51 or Z06. Unless these are aftermarket, I've got nothing else to go off of so any help identifying these would be appreciated.
Old Jan 23, 2021 | 10:19 AM
Gordy M's Avatar
Gordy M
More than likely the previous owner(s) were autocrossing the car in AS as it is legal to change one of the bars., have you check to see if you have adjustable shocks?
Old Jan 23, 2021 | 03:47 PM
tpr60's Avatar
tpr60
Your correct on the bar fitment. c6 zr1 front 33mm c5 zo6 rear 23.6mm
Old Jan 24, 2021 | 06:04 PM
OneBadBanana
These were from a seller I was speaking with. I'm sadly still on FE1 shocks
Thanks for the input! I'm thinking so too since no other answers point to any other brand otherwise.
To Need help identifying these sway bars
