question....UD pulley
Old Dec 9, 2002 | 03:49 PM
00c5coupe's Avatar
00c5coupe
Default question....UD pulley
if you swap cam and UD pulley. Does the pulley give you more HP compare to just a cam itself? how much more? Thanks!
Old Dec 9, 2002 | 03:58 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: question....UD pulley (00c5coupe)
I would say a cam is the best bang for the buck by far. A cam will usually pick up 30-50rwhp while a U/D pulley will probably pick up 5-12rwhp.
Phillip
Old Dec 9, 2002 | 04:04 PM
Patches's Avatar
Patches
Default Re: question....UD pulley (Phil97SVT)
Phillip
Truue, but, as they say, "While you're in there - WTH."
When I swapped my cam, I took the opportunity to upgrade the timing chain to the RollMaster dual roller set and added a ported oil pump and the UD pulley. Hey, I was already in there. :thumbs:
Old Dec 9, 2002 | 04:09 PM
hogurt's Avatar
hogurt
Default Re: question....UD pulley (Patches)
Does swapping the UD pulley cause any problems? What are the side effects?
To question....UD pulley
