Mysterious Headlight Issue
Old Jan 24, 2021 | 04:28 PM
adrielius's Avatar
adrielius
Default Mysterious Headlight Issue
I ran across a strange issue this week, I'd appreciate any info or advice.
1 - I replaced my DRL's with led bulbs. Fuse #6 is under the kick panel went out.
2 - Learned my lesson; unplugged the battery, replaced Fuse #6, and put the factory bulbs back in.
3 - Now the headlights stay open and the headlight motors make a clicking sound! On top of that, the headlights won't illuminate anymore.
I checked all the fuses connected to headlights and headlight motors, but I can't figure out what the issue could be. Is there a short somewhere or relay that had gone bad?
Thanks in advance!
Old Apr 3, 2021 | 09:39 PM
adrielius's Avatar
adrielius
Just FYI if anyone finds the same issue:
My battery managed to dip below 6 volts, so my charger thought it was a 6 volt battery instead of 12 volt. It would not charge beyond 6 volts, keeping it too weak.
Jumped it, ran it, maintained it at 12 volts, all is good now.
TLDR: some chargers misjudge a battery's voltage
Old Apr 4, 2021 | 08:22 PM
redzg's Avatar
redzg
Have to wonder why they still have a 6 volt capability. I don’t remember the 6 volt motorcycle battery I saw, much less automotive.
Old Apr 7, 2021 | 06:20 PM
grinder11's Avatar
grinder11
Only reason I can think of is they can be used on old, pre 1960s all original, classic cars with 6v systems. Otherwise.........
To Mysterious Headlight Issue
