HVAC CONTROL UNIT - C5 - Blanked Out ?
Old Jan 26, 2021 | 05:46 PM
Mav67's Avatar
Mav67
Default HVAC CONTROL UNIT - C5 - Blanked Out ?
The entire heating and ac control unit just went blank as if it had no power but was still working and then display lights came back on a few minutes later what's the fix for this?
Old Jan 26, 2021 | 07:11 PM
Smoken1's Avatar
Smoken1
Sounds like you need to re-flow the solder on the 241 resistors like in this video
Old Jan 26, 2021 | 07:12 PM
mmartinez's Avatar
mmartinez
Most likely bad solder joints on the resistors on the printed circuit board. Usual fix is to pull hvac unit out and retouch the resistors with a soldering iron and adding a little solder where the resistor contacts the board.
To HVAC CONTROL UNIT - C5 - Blanked Out ?
