Interior Temperature Sensor Question
Old Jan 28, 2021 | 05:52 PM
chevyorange's Avatar
chevyorange
Default Interior Temperature Sensor Question
So, I recently did the LED flasher upgrade so had to put the rapid flash unit in that is just behind the lower dash.
When I removed the trim piece, the temperature sensor (the housing) disintegrated. So, I've ordered a replacement but it is used - is there any way I should "clean" it before installing? Obviously it is a fragile piece.
Old Jan 28, 2021 | 10:14 PM
ericba's Avatar
ericba
St. Jude Donor '21-'22-'23
I wouldn’t bother myself. As you’ve found out, they can be fragile and since they are a simple device (thermistor), I don’t see how any surface contaminate would effect it.
Old Jan 28, 2021 | 10:15 PM
chevyorange
Thanks for the input. I'm literally going to touch it as little as possible!
Old Jan 30, 2021 | 12:16 PM
Chogan835's Avatar
Chogan835
This is extremely common. Unfortunately the part is discontinued but you can get a used one for pretty cheap.
Old Jan 30, 2021 | 01:47 PM
chevyorange
Found one for $20 on eBay and there were quite a few - one asking $90! hahahah I'm gonna handle it with kid gloves going in!
To Interior Temperature Sensor Question
