Transmission
Old Jan 29, 2021 | 04:36 PM
Houston Mattingly's Avatar
Houston Mattingly
2nd Gear
Default Transmission
Have a 2002 zo6 manual, won't down shift into third and keeps kicking out of reverse. Any ideas?
Old Jan 29, 2021 | 04:45 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Welcome to the forum! We're really glad to have you. You'll probably get a better response to this question in the C5 Tech section. Sorry I couldn't personally be more help.
Don't forget to SAVE THE WAVE!
Old Jan 29, 2021 | 05:21 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
Plus it will help to post a little more info about the car like mileage, how long you have owned it, maintenance history, does it have the anti-venom mod, if so how many washers, how long has it been occuring, etc. The more info you provide the better chance you'll get a better return on info.
I'm no expert on the Tremic T56 transmissions by no means, but it sounds like syncro's are shot.
Old Jan 30, 2021 | 02:13 AM
MetalMan2's Avatar
MetalMan2
First step is attempting shifter alignment, it's critical to try before proceeding down any other diagnostic path.
Old Jan 31, 2021 | 01:06 AM
Moved to C5 Tech.
Old Jan 31, 2021 | 01:38 PM
helga203's Avatar
helga203
Majority of people on here believe the tick MC will fix a very high percentage of clutch problems. Tons and tons of info out on your problem try them all if still dont work nrw clutch.
To Transmission
