Flasher not indicating in dash
Old Feb 3, 2021 | 10:47 PM
Sean_emory's Avatar
Sean_emory
Default Flasher not indicating in dash
My right flasher is not displaying in the dashboard or HUD but works fine on the outside of the car.
While I have my dashboard apart can someone tell me how to fix this. I wasn’t able to find a detailed explanation in my searches.
-Sean
Old Feb 5, 2021 | 07:56 AM
Sean_emory's Avatar
Sean_emory
Bump
Old Feb 7, 2021 | 09:24 PM
Sean_emory's Avatar
Sean_emory
Anyone dealt with this?
Old Feb 10, 2021 | 05:44 PM
Sean_emory's Avatar
Sean_emory
Bump
Old Feb 18, 2021 | 02:51 PM
Sean_emory's Avatar
Sean_emory
Anyone?
Old Feb 19, 2021 | 11:20 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
I have not heard of 1 going out. The emergency flasher switch likes to go out but that means both are not working.
I would be on the look out for bad connections, damaged wires, and I am not sure how it would be to bench test the light. It has been a long time since I have had a gauge cluster out.
Old Feb 19, 2021 | 12:15 PM
bradleyss14's Avatar
bradleyss14
You'll probably need a new bulb. Kind of strange for one to burn out, but we're talking about 15+ year old cars, so anything is possible. You can take any of the bulbs that are the same size and swap it into the turn signal to see if it works. The problem is, it's a fair amount of disassembly to get to that point. After re-watching the video, it looks like you won't have to remove the circuit board from the ribbons to get to the turn signal bulbs. Take the bulb out of the high beam indicator out and use it in the RT signal slot. Put the IC almost all the way back together and plug in the IC again. You've done the hardest part already by taking the dash off, this is just a few more T15 and Phillips screws.
Here's the turn signal bulbs on the back of the IC.
Here's a video on how to get it apart to this point.
Old Feb 19, 2021 | 01:03 PM
silver50's Avatar
silver50
He was saying there was no signal displayed on the HUD too (I didn’t know the HUD showed turn signals but I guess it does..?) so I’m guessing it’s not down to a cluster bulb?
To Flasher not indicating in dash
