Electrical wizard needed!!
Old Feb 4, 2021 | 02:08 PM
OregonDan's Avatar
OregonDan
Default Electrical wizard needed!!
My '99 has developed a new vexation for me. When fired up from cold, the OP gauge reads fine, but the HUD OP indicator says zero. As it warms up, the gauge OP drops and the HUD OP indicator begins to work, but slowly (one bar at a time) until the gauge and the HUD read pretty much the same. Weird, huh? What the H is going on? There's only one sending unit (feeds both gauge and HUD), so it shouldn't be bad. HELP!!
Old Feb 4, 2021 | 03:10 PM
Speedy007's Avatar
Speedy007
Don’t understand your language here ....are u talking about the oil gauge ? There’s a sensor on the back of the engine known to just go out without warning...
Old Feb 4, 2021 | 09:20 PM
OregonDan's Avatar
OregonDan
Yes, the oil pressure gauge and the oil pressure display in the HUD. There is an oil pressure sending unit on the back top of the block and it sends its signal to both the gauge and the HUD display. How can they read differently?
Old Feb 4, 2021 | 10:24 PM
Speedy007's Avatar
Speedy007
Prob a bad sensor change it out ...with lifetime warranty on the replacement sensor ....
Old Feb 4, 2021 | 10:35 PM
robmiz's Avatar
robmiz
From what I understand the oil pressure sending unit send the signal to the PCM. The PCM then send the data to IPC. My guess your problem might be with the IPC.
Old Feb 5, 2021 | 10:08 AM
bjones7131's Avatar
bjones7131
I know U want to find the problem and I would too but if they both settled out after a bit I would live with it until it completely went south. Good luck with it
To Electrical wizard needed!!
