Key will not open or lock door
Old Feb 6, 2021 | 11:09 AM
Revel4X4's Avatar
Revel4X4
Default Key will not open or lock door
Started last week on my C5. Fob will unlock and lock the driver's door. Using the key, nothing happens. Does anybody have pictures of the lock cylinder linkage?
Take it door panel will have to come off, like to see what parts I need for this repair.
Old Feb 6, 2021 | 11:35 AM
punk86's Avatar
punk86
Have the window rolled up. Take off the door panel and put your hand in the door and stick it back in. Takes maybe 5 to 10 minutes
Old Feb 6, 2021 | 05:35 PM
Revel4X4's Avatar
Revel4X4
Do any clips or screws have to be replaced?
Old Feb 6, 2021 | 06:51 PM
punk86's Avatar
punk86
When I did mine, I didnt have to replace anything. It just popped in and that was it
Old Feb 9, 2021 | 11:22 AM
grinder11's Avatar
grinder11
"Nothing happens"??
Is your lock cylinder frozen up from non use?
Old Feb 9, 2021 | 11:37 AM
Revel4X4's Avatar
Revel4X4
"Nothing happens"??
The key turns in the lock cylinder fails to unlock or lock doors.
Old Feb 9, 2021 | 01:06 PM
grinder11's Avatar
grinder11
Sounds like one, or more of the tumblers aren't working, or the linkage is broken or fell off. Does the door have a rattle inside? When you use the FOB to unlock/lock, does the flipper on the door move back and forth?
To Key will not open or lock door
