Windshield washer issues
Old Feb 7, 2021 | 09:01 PM
Dialtapper's Avatar
Dialtapper
Cruising
Default Windshield washer issues
I recently purchased a 99 C-5 convertible with 10,000 miles. The car is flawless, except I serviced the windshield washer fluid, when I hit the button to wash the windshield fluid only comes out of the drivers wiper and it pisses fluid under the car from just inside and behind the left front tire.
Any advice or insight would be much appreciated.
Thanks in advance.
Old Feb 7, 2021 | 10:54 PM
rrwirsi's Avatar
rrwirsi
Check the hoses from the tank to the wipers. I had a leak in the one just before the "t" to the left and right nozzles.
Old Feb 8, 2021 | 11:53 AM
Chogan835's Avatar
Chogan835
Check the lines. You’ll need to take off the cowell most likely. Also check the lines at the washer arms. Sometimes those clog. Did on mine.
Old Feb 9, 2021 | 08:12 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
One thing that I've learned, over the years, is that windshield washers, especially on cars that are seldom driven, will crap out prematurely. Prior to buying my C-5, I owned a '77 Pontiac T/A, for 25 years. I probably used the washers, MAYBE, 4-5 times during that time, and just before I sold the car, I found that they didn't work. I'm sure the system "dried out", because it certainly wasn't "worn out".
Using that experience as a warning, even though my C-5 has low mileage, and is seldom driven in the rain, I'll "exercise" the washers, a couple of times, when I wash the car. I cycle the washers a couple of times, then rinse the fluid off the car, as I wet the car to begin washing it.....
Old May 30, 2021 | 11:38 AM
shaark92's Avatar
shaark92
I have this issue, too ... thanks for posting.
now to dig around and fix it. "Valerie" is a driver, so she unfortunately gets exposed to wet roads. Need the washer to function normally.
Do any of the vendors have "plug/play" replacement hose lines?
To Windshield washer issues
