A4 Tranny...is it slipping???
Old Dec 10, 2002 | 01:47 PM
vetteboy2k's Avatar
vetteboy2k
Default A4 Tranny...is it slipping???
I have recently experienced my tranny not feeling as strong as in recent past. I have a 2000 A4 with 3.15 performance axle, 3000 stall yank converter w/2.0 str and TTS PowerloaderII. Also the tranny and diff fluid was flushed recently.
What is happening is sometimes when downshifting the car doesn't go into gear and just rev's until I let off the throttle. Also on some sprints the tach bangs off the rev limiter. And today I was coming on an on-ramp and was easing it up to 65-70 in 3rd and then it started revving again. I let off the throttle and it went back to normal.
What is everyone's opinions???
Old Dec 10, 2002 | 01:56 PM
RWhite's Avatar
RWhite
Default Re: A4 Tranny...is it slipping??? (Buckmaster)
This may not be it, but when my OD band went south in a few of my Mustang AOD trannies, it did a similar thing.
vetteboy2k's Avatar
vetteboy2k
The dealership did the trans and diff flush. So I am assuming it was what GM reccomends.
Old Dec 10, 2002 | 02:11 PM
vstella's Avatar
vstella
Default Re: A4 Tranny...is it slipping??? (vetteboy2k)
Sounds like the 3-4 clutch pack is toasted..Sorry, but these GM 4L60E tansmission are not really built for abuse. I rebuilt mine after only 20K and installed a Transgo shift kit and now it's the best transmission out there..BULLETPROOF! :smash:
I would have you give a call to our resident CF transmission expert Steve Atkins at www.eastcoasttransmissions.com and get his opinion. Either way you need to seriously consider a Transgo kit!!...It works! :yesnod:
Old Dec 10, 2002 | 02:15 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default Re: A4 Tranny...is it slipping??? (vstella)
:iagree: Yup your 3-4 is gone! Happened to me last spring with only 1600 miles on it! Not to mention, they found debris in the valve body! It was some dudes finger from the factory! :eek: Just kidding :lol:
Definitely take it back to the dealer if your still under warranty! OH WAIT - you gotta TC.......Guess there is no warranty! :smash:
[Modified by y2k02c5, 2:15 PM 12/10/2002]
Old Dec 10, 2002 | 02:32 PM
vetteboy2k's Avatar
vetteboy2k
Default Re: A4 Tranny...is it slipping??? (y2k02c5)
Well I will talk to the service place today. I am still under warranty so we will see what happens.
Vstella,
By the way what is it that the trans-go does that makes the transmission bullet proof? What functions does it have?
[Modified by vetteboy2k, 2:40 PM 12/10/2002]
Old Dec 10, 2002 | 07:20 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Vstella,
I would try the dealer all they can say is no. I would not tell them I have an after market converter, they them figure that out.
No the Transgo Kit does not make it Bullet proof, upgrading with heavy duty parts should do it.
Old Dec 10, 2002 | 10:58 PM
vetteboy2k's Avatar
vetteboy2k
Default Re: A4 Tranny...is it slipping??? (wallstAL)
Well, I spoke with the dealer and they are going to put a scanner on it to see what is happening. Guess I will have to wait and see.
Thanks guys :thumbs:
Old Dec 10, 2002 | 11:05 PM
hogurt's Avatar
hogurt
Vetteboy, do you have a tranny cooler? Did you take any preventative measures when you added the TC?
I am just wondering because I am about to have a TC installed also. It was my understanding that adding the cooler and the transgo would make the tranny much more stable?
Good luck w/ the dealer, keep us posted! It just makes me :U to hear about your problems!
Old Dec 10, 2002 | 11:14 PM
vetteboy2k's Avatar
vetteboy2k
Default Re: A4 Tranny...is it slipping??? (hogurt)
No Hogurt I didn't add any tranny cooler or the trans-go. The TC was installed at around 25,000 mi and I am now at 70,000 mi. I do mostly highway driving but more recently have been doing more around town. I am not easy on my car, but in no way am I abussive.
I think everything will work out ;)
Old Dec 10, 2002 | 11:20 PM
vstella's Avatar
vstella
Vstella, By the way what is it that the trans-go does that makes the transmission bullet proof? What functions does it have?
The Transgo shift kit is a MECHANICAL modification..not electronic ! The shift kit will firm up your shifts and give you more control in manual upshifting as well as downshifting..Crisp,sure and durable shifts every time..I would also recommend you think about a deeper trans pan rather than a cooler..IMO:D
It will not bulletproof the trans alone but with HD parts such as wider kevlar bands and 9 disc 3-4 clutch packs ,5 gear planetary units among many others parts will..!:D More information on these and more performance partswww.transmissioncenter.net.. :chevy
[Modified by vstella, 11:22 PM 12/10/2002]
Old Dec 10, 2002 | 11:31 PM
vetteboy2k's Avatar
vetteboy2k
Thanks Vstella,
I read up on the trans-go and what it does. I will be seriously thinking of putting this in when fixing the trans. Plus I don't think its the 3-4 clutch maybe the 2-3 clutch b/c that when it seems to slip, or flare as you may. When it happened today it was when I had the shifter in 3. The trans downshifted to 2 and then as it tried for 3 thats when it slipped. Hopefully the scanner will show whats happening.
To A4 Tranny...is it slipping???
