Intermittent HVAC operation
Old Feb 10, 2021 | 10:47 AM
Larry Hargrove's Avatar
Larry Hargrove
Default Intermittent HVAC operation
My car is a 2001 convertible. The HVAC control works sometimes and other times it doesn't. I had Dave at Corvette Illuminations check it out and he said it works fine. He even put it on his personal car and it worked fine. There is obviously a short somewhere; I have checked fuses and connectors and I am just about to pull my hair out. Does anybody have any clue what my problem might be?
Old Feb 10, 2021 | 03:56 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
The first question is who’s Dave and is he a Tech ??...no idea what Corvette Illumination is ??...if your talking about your HVAC control module and he said the module is fine in his car maybe the module is OK...exactly what is happening ??...what makes you think there is a short ??...does the AC light come on when the AC is selected ??...pull the codes from the DIC and post what you see...this concern of yours can be a few things so there is NO magic bullet here unfortunately.
Old Feb 10, 2021 | 06:36 PM
Larry Hargrove
What it does is sometimes nothing. No lights and nothing works, like it is getting no power. Other times I turn the key on and it lights up and everything works like it is supposed to.
Old Feb 10, 2021 | 08:00 PM
SilverC54me's Avatar
SilverC54me
Sounds like an ignition switch contact issue. As these cars age the contacts in the ignition switch get a carbon buildup from arcs as they are operated.
Have taken several apart and always find the same thing, black spots on the contacts. This buildup needs to be sanded off and it may be necessary to add a bit of bend to the contact arms so they make better contact.
If you are in SoCal I can help with this.
Gary
Old Feb 10, 2021 | 08:26 PM
C5 Diag's Avatar
C5 Diag
The only thing I can tell you is you would have to check the module’s power and grounds when it’s not working...don’t know what else to tell you...not knowing your electrical skill set I won’t elaborate on how to diagnose this !!
Old Feb 10, 2021 | 08:50 PM
Larry Hargrove
Gary
I replaced the ignition switch back in the summer.
Old Feb 12, 2021 | 01:47 PM
Chogan835's Avatar
Chogan835
I don’t think an ignition switch would cause this issue. If the ignition switch was going bad I would say you’d have other major electrical issues.
Do you have access to another unit to test and try IN YOUR CAR? We first have to find out if it’s the car or the module. How long have you owned the car? Sometimes people try and fix the dim light issue and hack up the boards and cause major problems.
I did a quick and easy google search about corvette illuminations. Looks like dave does lighting repair. Did he do any work to your ac module? In order to help I would need a little more information.
Old Feb 13, 2021 | 09:48 AM
Larry Hargrove
I replaced the ignition switch back in July so I am pretty sure that is not the problem. I have owned the car for almost 3 years. In that time I've not found any signs of previous electrical butchery. It had only 20k miles on it when I bought it. Dave went in and resoldered the 8 resistors that normally cause the lighting problem. After that he plugged the module on his own 'Vette and said that it worked perfectly. He seemed to be knowledgeable and and honest so I have no reason to doubt his word.
Old Feb 13, 2021 | 11:04 AM
Chogan835's Avatar
Chogan835
Now we are getting somewhere. I would double check the connection on the back of the module. Make sure it’s pushed in all the way. If that doesn’t work, I’d say Dave owes you a new module. Sounds like he accidentally broke something that’s causing your intermittent problems. You can find some fairly cheap ones on eBay.
Old Feb 13, 2021 | 11:50 AM
Larry Hargrove
No. It was already not working when I sent it to Dave. He said that he would check it out for me.
Old Feb 13, 2021 | 01:42 PM
silver50's Avatar
silver50
If the unit has been out and in it doesn’t sound like it’ll be the connector.
As C5Diag is suggesting, the next steps would be testing whether the unit is getting power to it when it isn’t working.
I suspect it’ll mean needing to “back probe” the connector to see if power is or isn’t there. Also indeed checking the ground. I suspect it’s not a bad ground if it’s either completely fine or completely off though.
My gut is that the HVAC head isn’t right but a person would want to check incase power getting to the unit is cutting.
If you’re handy with a multi meter and could back probe the back of the connector after getting to the unit post back. C5Diag may hopefully guide you more.
Old Feb 13, 2021 | 01:48 PM
Chogan835's Avatar
Chogan835
I would just replace it. If it worked perfect before, then Dave “fixed” the backlights by disassembling and soldering the board, and now it doesn’t work........you already have the answer as to what went wrong. These things just don’t break on their own. Next time it doesn’t work take a video and send it to Dave.
also, those connectors back there can be very sensitive and cause problems if not pushed all the way in firmly.
Old Feb 13, 2021 | 02:14 PM
silver50's Avatar
silver50
I think he’s making out it was doing this before it was pulled and worked on
Old Feb 13, 2021 | 02:24 PM
Chogan835's Avatar
Chogan835
I don’t think that’s what he saying.
Old Feb 13, 2021 | 02:45 PM
silver50's Avatar
silver50
Dave at Corvette Illuminations checked it out AND AT THE SAME TIME went in.
So it must’ve been playing up prior to being opened up.
Old Feb 13, 2021 | 03:21 PM
Chogan835's Avatar
Chogan835
sorry. I don’t understand your post. Playing up? At the same time went in? None of that makes sense.
let’s let the op explain further. He’s also not very clear if it’s just an illumination problem or a functional problem.
Old Feb 13, 2021 | 03:53 PM
Larry Hargrove
Sounds like I've got some testing to do but the high temps are not expected to be above freezing for about a week to 10 days so it will be a while.
To Intermittent HVAC operation
Old Feb 13, 2021 | 04:10 PM
silver50's Avatar
silver50
The very first post explains that the unit was already exhibiting the fault when it was given to Corvette Illuminations.
“Playing up” is a figure of speech. Maybe one not used in US. We use it if something isn’t right. You’d say it was “playing up”.
When I said “went in” I was referring to opening up and going into the HVAC control head.
OP, good luck on getting it checked out. Seems sensible to try and check the power feed. A simple test light probing the orange wire should let you know what’s happening.
Old Feb 13, 2021 | 04:43 PM
Chogan835's Avatar
Chogan835
Yeah, “playing up before opening up” isn’t something we know in the US. No worries. I understand you now.
Old Feb 23, 2021 | 07:49 PM
Larry Hargrove
I finally got to work on this again and something happened that made me wonder. I had been working all day and had no luck at all. I was getting ready to call it quits for the day. I turned the ignition to off and the feature that let's the accessory like the radio stay on until you open the door kept the radio going kicked in. All of a sudden volume almost went off and the antenna started to go down. Then the volume and the antenna went back up and I saw that the hvac controller was working for the first all day. Does any of you have a clue as to whether any of these things could be my problem?
