C5 trans axle differential swap?
Old Feb 11, 2021 | 01:37 PM
DeSoto Dan's Avatar
DeSoto Dan
4th Gear
Default C5 trans axle differential swap?
Greetings to all on the forum, just learning the ropes, as it were, of the C5 Corvette. The question I have today is... will the GETRAG 2.73 LSD
interface with the standard 6 speed transmission? Yes... we are looking for top end performance and high speed low rpm parameters
Cheers!.
Old Feb 11, 2021 | 01:40 PM
jehuds10's Avatar
jehuds10
Welcome, try asking here.
https://www.corvetteforum.com/forums/c5-tech-1/
Old Feb 11, 2021 | 03:29 PM
Moved to C5 Tech.
Old Feb 11, 2021 | 03:49 PM
rjacobs's Avatar
rjacobs
I dont believe the auto diff's have a speed sensor in them...
Old Feb 11, 2021 | 04:21 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Yes they do
Old Feb 11, 2021 | 06:37 PM
493lszosix's Avatar
493lszosix
Yes it will bolt right up, you just need to remove the large seal, it’s only used on auto’s
The seal/aluminum piece that says trans side in pic will not be used if going into manual transmission just remove it but you will need a new o ring seal where the trans mounts to diff
Old Feb 11, 2021 | 07:44 PM
DeSoto Dan's Avatar
DeSoto Dan
4th Gear
Very good news for us! Thank you for your response, perhaps, at some time, I shall be able to return the favor of question answered...
thank you very much!😎
To C5 trans axle differential swap?
