I need to replace the harmonic balancer on my 97 C5. I see summit has one for $200 for racing one. I have opportunity to buy brand new ATI 10% balancer for $215.00 shipped.
My questions is is it worth going with underdrive pulley?
Will I gain some horsepower with ATI?
Does 10% underdrive balancer mean it's 10% smaller in diamater than oem one? will I need shorter belt?
Is $215.00 good price?
I plan on installing the BTR stage 2 Cam kit, LS intake, 243 zo6 Cylinder heads, and Speed Engineering exhaust at the same time.
You'll gain a few whp, maybe 3-5 max. If you buy the ATI, make sure it's got a 'lip' at the front/back of the serpentine belt grooves. Hib Halverson has posted a good thread in the C6 Z06/ZR1 section about how the lack of that lip has caused him to throw belts at high rpm. He specifically mentions the problem is with the ATI balancer. Don't remember the exact specifics. I went with an ASP 25% underdrive balancer, but I also have a larger DeWitt radiator. I can't guarantee you won't run into cooling issues going to a 25% underdrive pulley and a stock radiator. ASP makes a good balancer for a good price. Mine is over 10 years old, never any trouble. Good luck.......
Def go with the ATI but stock size. 10% underdrive does nothing for performance.
I don't kdon'what stock size harmonic balancer is, I guess I will have to research to find out. The only reason I'm considering getting the 10% underdrive ATI balancer is I can get one that is brand new for $215 shipped. Brand new one is like $335.00. The ATI this seller has is old one and summit says out of stock they don't know when and they may not stock this one again. I can get summit racing harmonic balancer for $199.00. Tough decision.
which one should I go with? Racing one from Summit? Or 10%ATI UNDER DRIVE BALANCER?
The summit brand balancer is a great quality piece. I just installed one with no problems. It can be installed to replace the oem but also has extra groves on it if you want to run a supercharger. Looks nice too.
Did you install the racing one $199 ?
Even though that one has a extra rob it doesn't matter I can still use it?
And I can use orignal oem belt size with that one?
