Windshield Wiper Issues
Old Feb 21, 2021 | 08:01 AM
Decibob's Avatar
Decibob
Default Windshield Wiper Issues
After reading many threads I have come to the conclusion that I may have a bad wiper control stalk so wanted to run this by the group for inputs.
My issue started with one wiper not seating all the way down when off, probably 3" away from seating hump. Several weeks later the other arm did the same. Now the washer fluid doesn't work ( this may be due to the steering column replacement at the dealership but not sure).
All stalk controls seem to work properly such as intermittent settings but I am finding this odd. Any help would be greatly appreciated. I am about to check for leaks from reservoir today.
Old Feb 21, 2021 | 12:34 PM
Chogan835's Avatar
Chogan835
If you recently had the steering column replaced and now having wiper and related issues I would take it back to them. Something didn’t go back together correctly.
Old Feb 21, 2021 | 03:19 PM
Decibob's Avatar
Decibob
Only the washer went out after steering replacement, wipers not seating was before the steering column replacement. I should have been clear on the sequence of events and thanks..
Old Feb 22, 2021 | 12:23 PM
Decibob's Avatar
Decibob
Any feedback? I know this is a subject beaten to death but I cant find consistency in responses for my specific issue.
Old Feb 22, 2021 | 01:49 PM
Chogan835's Avatar
Chogan835
So the wipers work, they just don’t seat down properly? Do a search for “windshield washers won’t park.” Looks like you need a new motor and/or transmission.
Old Feb 22, 2021 | 05:16 PM
Decibob's Avatar
Decibob
Thanks, guess at the ripe old age of 23 it's probably time to knock out the wiper system and be done with it. I will research as suggested and appreciate the feedback!
Old Feb 22, 2021 | 05:28 PM
Smoken1's Avatar
Smoken1
Check your udders they may be plugged causing the cowl area not to drain properly
Old Feb 25, 2021 | 08:50 AM
Decibob's Avatar
Decibob
Udders are good and snipped the ends several years ago for better drainage, thanks for the input!
To Windshield Wiper Issues
