Oil pan leak
Old Feb 26, 2021 | 01:51 PM
02vetteboy's Avatar
02vetteboy
7th Gear
Default Oil pan leak
I'm not driving my vette as much as I used to so when I last took it out, I noticed some oil on the garage floor. My mechanic checked it and told me there was a leak around the oil pan and the only way to replace the gasket was to pull the engine. Is that correct?
Old Feb 26, 2021 | 02:02 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
If it's the upper pan, yes.
Old Feb 26, 2021 | 02:23 PM
rrwirsi's Avatar
rrwirsi
Or try Titan Oil Stop-Leak. I had the same diagnosis with my 04 Murano. I Needed to pull the engine to fix the upper pan gasket. No Way. I either will put up with the leak or try something else. I researched and found the Product TITAN Oil Stop-Leak. I decided what the he**, and bought it. Not cheap. But it is still working after 12 months AND if it starts leaking again, you get a second free.
Old Feb 26, 2021 | 02:25 PM
Stingroo's Avatar
Stingroo
$120 for the high capacity version? Holy crap.
Old Feb 26, 2021 | 02:42 PM
rrwirsi's Avatar
rrwirsi
But compare to an engine pull?? I rolled the dice and it worked for me.
Stingroo's Avatar
Stingroo
Just curious - how long has it been?
Old Feb 26, 2021 | 02:44 PM
Bandit 00C5's Avatar
Bandit 00C5
2023 Corvette of the Year Finalist - Modified
2022 C5 of the Year Winner - Modified
You do not have to pull the motor. I just did this job on 2 C5s. You can support the motor from above and drop the front suspension out. If you take your time this is a fairly easy job. Mine and my friends were leaking pretty bad and we had had enough.
Old Feb 26, 2021 | 02:49 PM
Stingroo's Avatar
Stingroo
That's another good option I suppose. The subframe would come out easily enough.
Old Feb 26, 2021 | 02:52 PM
Stingroo's Avatar
Stingroo
Interesting - I just looked and AllData also suggests to lower the front suspension. They say 5.9 hours.
Old Feb 26, 2021 | 02:54 PM
rrwirsi's Avatar
rrwirsi
Over a year, 15 months +. No leak, or no smell of burning oil on Headers. Very pleased with the result. But probably not so with many of the purist crowd on fixing things.
Old Feb 26, 2021 | 02:55 PM
Stingroo's Avatar
Stingroo
Hell, I'm all about a short cut if it works. How many miles in that 15 months?
Old Feb 26, 2021 | 02:58 PM
rrwirsi's Avatar
rrwirsi
It is my DD so about 4000 miles. Being retired, I do not drive as much as I did 10 years ago.
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
This is how mine was fixed. I needed to get an alignment afterwards though.
Old Feb 26, 2021 | 10:40 PM
Fire Alarm Guy's Avatar
Fire Alarm Guy
Default Just MHO
I have never been one for 'miracle cure in a bottle'. Not saying what was recommended is good or bad, just have never had one work for me, over promised and under delivered.
Kind of like putting a raw egg in your radiator to stop a small leak. Sure it hard boils and stops the leak temporarily and clogs up a lot of other small passages that you didn't want plugged.
Bite the bullet and fix it right.
Old Feb 26, 2021 | 11:21 PM
Smoken1's Avatar
Smoken1
If it's the lower pan try to re-torque the bolts
Old Feb 27, 2021 | 01:55 PM
rrwirsi's Avatar
rrwirsi
I agree. I had the same thoughts for the oil leak fix until I used the Titan product. There are some chemical products out there that do work. The other one I found worked for me was Reslone oil treatment that I used to quite noisy lifters in my Maxima.
Old Feb 27, 2021 | 11:31 PM
Moved to C5 Tech.
Old Feb 28, 2021 | 08:34 AM
eric22's Avatar
eric22
No requirement to pull the engine to replace any of these gaskets. I think some stuff needs to be removed from the sides and front of the engine.
Old Feb 28, 2021 | 10:45 AM
Chogan835's Avatar
Chogan835
Had my upper replaced. Engine def was not taken out.
To Oil pan leak
