LMC5 Install & Questions
So, I decided to install an LMC5 from Compliance Parts as a bit of preventative maintenance on the ‘01 Z. I did the install on my old ‘02 Z without any issues. However, this time around I’m a bit stumped. I followed the instructions per my situation (no column lock messages or pull key messages on the DIC), and got everything installed with no real issues (other than destroying one of the 20 year old brittle blue retention clips for the harness on the BCM...photo below). Once the module was installed, I went to turn the ignition to “on” to make sure I didn’t have any nasty messages on the DIC. None! Perfect, so I go to crank the car over and...nothing. I try one more time and even more nothing. As in, now I have zero power going to anything. When the key is in the “on” position, I have no power lighting up gauges, DIC, center console, etc.
Looking at Compliance Parts’ LCM5 trouble shooting page, I go through all of the fuses that have anything to do with the BCM. They are all good; none are blown. I thought perhaps my battery wasn’t as good as I thought, so overnight I put it back on the CTEK to charge/recondition the battery. This morning the CTEK shows everything is dressed-right-dress on the battery, so I go to crank the engine...and again; nothing. No power going to anything.
I realize Richard from Compliance Parts is very helpful, however, it is Sunday and I know he needs time off just like anyone else. Before I start calling him tomorrow, can you guys offer up any possible solutions? I’m certain there is some random fuse somewhere that I am not checking. And the negative cable for the battery is securely reinstalled. Maybe the blue retention clip on the green BCM harness is the culprit? Anyone know of where a replacement one can be purchased?
The remains of the blue retention clip...
I’m open to any suggestions and thank you in advance!
Out in the garage checking fuses...
10-4. Standby and I will go check. I appreciate your help with this.
But here is something else weird, when I first touched the hot side of the battery, the car “came alive.” The interior lights came on. So, I hopped in to try and start it, had the courtesy tone when I put the key in, gauges were alive. Turned the ignition to start...and...nothing. Now everything is dead again.
My thoughts exactly. Weird that it did this with the installation of the LMC5 though. Car was operating perfect prior to this. Could the installation cause a rapid draw on the battery? I know C5s are very sensitive to battery issues though.
Off to the auto parts store...
Thank you again for your help.
So, here’s what I love about cars. Right when you have the confidence to think you know what you’re doing, you’ll be shown the error of your ways. Lol.
I go to pull the battery and the negative cable is nice and secure. Remove it and move to the positive side. Barely half a turn of the box-end wrench and it falls right off. Hmmm. Re-secure it and re-secure the negative; car comes alive.
Fires right up.
How many beers do I owe you Old School?
This is a good lesson in not jumping to conclusions about what the problem might be. With the information I had at-hand, I was sure the LMC5 was at fault. However, once I discovered the positive battery cable was loose, obviously the problem was the guy behind the wrenches.
Thanks again Old School for helping me take a second objective look at everything!
Nothing like a loose positive battery cable to humble you on a weekend. I’ll hit the terminals with baking soda and vinegar later this week. Snugged up the positive side and got it nice and tight. It all works now much to my wife’s disbelief!
