Reduced Engine Power - throttle position sensor 1-2 correlation
Getting your opinions to see if I've conclusively proved it's the throttle position sensor I need to replace in my 1997 C5.
So I'm getting Reduced Engine Power of course, car really labors under 2k rpms, idling irregularly.
Codes that are current:
** P1221
** C2120
TPM System Malfunction
(I'll assume the tire pressure monitor system is not relevant here. Just wanting to fix the engine problem!)
So I took a digital multimeter (dmm) to the tire pressure sensor connector.
I verified it was measuring correctly by measuring the battery at idle (~11.8V)
Then I measured the pink wire which is sensor 2 and the dark blue wire which is sensor 1.
I disconnected the harness from the throttle body to directly measure the output of sensor 1 and sensor 2.
Fortunately my car doesn't always throw reduced engine.
So the measuring session started without the reduced engine power state, and I was able to measure voltage would go up and down alternately for sensors 1 and 2.
I did this by
1) disconnecting the harness from the throttle body
2) inserting my dmm probe in the correct harness lead position (from the factory service manual) then having a friend alternate between no throttle, half way throttle, full throttle.
Measuring Sensor #1 at the 4th position in the harness
Measuring Sensor #2 at the first position in the harness
When reduced engine power was NOT showing up,
Sensor 1 correctly decreased from 4V down to ~0V as the throttle was pressed.
Sensor 2 conversely increased from 0.3V to 4V(?) as the throttle was pressed.
Luckily right after I started measure the reduced engine power state started!
At that point,
Sensor 1 stayed at 4V.
Sensor 2 stayed at 0.3V.
This remained the voltage no matter if the throttle was pressed or not.
Is this definitive proof that I need to change the Throttle Position Sensor? Any other things to check?
It's definitely weird that the measuring goes from successful to total failure seemingly with no gating event.
The car just flips out! 🤔
OR do I need to figure out what's causing the TPS to go from working to non-working? Will sensors work then not work? Sporadically?
I had my battery and alternator tested, both by autozone and by a battery tester I have, battery was good, alternator was good.
Thanks for any ideas!
