Quick question about 99 c5 stock injector pintles.
Old Mar 6, 2021 | 05:41 PM
Norcal707's Avatar
Norcal707
Default Quick question about 99 c5 stock injector pintles.
Just a simple question, I bought some different pintles for my 280-155-890 bosch injectors. The old pintle caps broke when. I went to remove the fuel rail to wash my intake manifold. Will these after market ones work? Or will they create a leak? Thanks!
Old Mar 6, 2021 | 09:11 PM
jamieo's Avatar
jamieo
They won't leak unless the o-rings are bad.The pintle is only there to keep the o-ring on the injector when you remove them from the intake.
Old Mar 7, 2021 | 07:36 PM
Norcal707's Avatar
Norcal707
Do the pintle caps sit inside that little edge in the injector holes on the manifold?
Old Mar 7, 2021 | 07:56 PM
jamieo's Avatar
jamieo
Yes,but the o-ring is what actually does the sealing.
Old Mar 8, 2021 | 12:44 AM
Norcal707's Avatar
Norcal707
thanks, I wasn't sure since theres that round edge inside the intake Injector holes.
To Quick question about 99 c5 stock injector pintles.
