Car isnt turning on 😕
Old Mar 13, 2021 | 05:47 PM
C5.dro's Avatar
C5.dro
Default Car isnt turning on 😕
So i was leaving work and when i tried turning my car on nothing happened, so had to tow it back home. Checked for codes and nothing only past codes i have and current are all from tpms related and my traction control. Battery is working had it load checked my connection are good. When i put my key on the on position everything lights up like it normally does but when i try to crank it or hold it on the crank everything turns off and when i let go the dash lights back up normally.
Old Mar 13, 2021 | 08:33 PM
Life’s good C5's Avatar
Life’s good C5
This should be in tech, but as no one has responded I will try. Possible bad ignition switch. Possible bad neutral safety switch. At least it’s a start. Try putting in in Neutral and the crank the engine. Maybe someone can advise how to test the ignition switch
Old Mar 13, 2021 | 08:38 PM
ThomasR's Avatar
ThomasR
Listen for a single click from the starter when you go to crank. It might be stuck. If it is a few rapps with a hammer might get it working again temporarily.
Old Mar 13, 2021 | 11:38 PM
jim993's Avatar
jim993
You should have an inexpensive ($20 or so) multimeter on hand.
To help diagnose this, have someone help by monitoring battery voltage across the battery terminals with a meter when you attempt to start. A well charged good battery should be close to 12.6 volts across the battery terminals with no load. If battery voltage stays up at 12.6 or above during an attempt to start but dash lights go out, that points to a bad connection at the battery, bad battery ground at frame and or engine or bad ignition switch.
You say the connections and battery test good. With the battery side terminals tightened securely (11 foot pounds per FSM) you should not be able to move the cable connections at the battery by hand. If you can, there is a problem with the connection.
If battery voltage across battery terminals drops substantially during an attempt to start, that points to a bad battery, bad starter solenoid or bad starter. If so FIRST try a KNOWN good battery FULLY charged. I am suspicious of parts store load tests.
Old Mar 14, 2021 | 01:23 AM
Moved to C5 Tech.
Old Mar 14, 2021 | 10:53 AM
mmartinez's Avatar
mmartinez
The very first thing to check is the TDR, Theft Detterant Relay, it is located on top of the BCM in the passenger footwell area. This relay sends power to energize the starter, it should click on every time you turn the key to the start position. Verify that it is or not clicking and post back and we can go from there.
Old Mar 14, 2021 | 01:11 PM
C5.dro's Avatar
C5.dro
yes it does click
Old Mar 14, 2021 | 02:11 PM
mmartinez's Avatar
mmartinez
Could be the contacts inside the TDR, loose battery cable connections at the starter solenoid, or a failing starter/solenoid. I would try the earlier suggestion of whack the starter with a wooden broom handle or long piece of wood. There is also a test which involves placing a heavy gage wire jumper between the red and violet wires at the TDR socket. Extreme CAUTION when doing this as this bypass's the requirement for the car to be in Park or the clutch pedal being depressed, it will crank over even if the car is in any gear, if the car cranks then your TDR needs to be replaced, if nothing happens then it is probably your starter/solenoid.
Old Mar 14, 2021 | 02:34 PM
C5.dro's Avatar
C5.dro
where is the starter or where do i hit it? Im looking online amd they say it’s underneath?
Old Mar 14, 2021 | 03:26 PM
mmartinez's Avatar
mmartinez
The starter is located on the passenger side of the engine underneath the exhaust manifolds. Follow the positive battery cable down to the starter, whack the small metal cylinder that sits on top of the starter, that is the solenoid.
Old Mar 14, 2021 | 08:32 PM
C5.dro's Avatar
C5.dro
life saver 🙏🏽 I hit the starter and still nothing i said it’s already up in the air I might as well change it wether it is or isn't the problem and after several hours and a whole lot of cussing it finally turned on lol thanks
Old Mar 14, 2021 | 08:45 PM
Chogan835's Avatar
Chogan835
Ignition switch
Old Mar 14, 2021 | 08:52 PM
C5.dro's Avatar
C5.dro
Originally Posted by Chogan835
Ignition switch
forgot to add that i had a similar problem 4 months back and it was in fact the ignition switch and I replaced it, I thought maybe it was that again but no, it was the starter
Old Mar 14, 2021 | 09:32 PM
mmartinez's Avatar
mmartinez
Good to hear you got your car going, that's what the forum is all about, helping fellow corvette owners.
Old Mar 17, 2021 | 03:54 PM
Speedy007's Avatar
Speedy007
I would said push it down hill and pop the clutch ....
Old Mar 17, 2021 | 08:09 PM
helga203's Avatar
helga203
u sure u didn't mean push it down a cliff.
To Car isnt turning on 😕
