LS1 Balancer advice
Old Mar 14, 2021 | 02:49 PM
TheCrow's Avatar
TheCrow
Default LS1 Balancer advice
Hey Guys--So I am planning a cam swap in my 99 FRC this summer. I will be replacing the balancer as well before it gives a problem. Seen some good reports on teh Summit Racing unit. What others should I look at? The car is a daily that is getting a mild cam, headers, intake, TB, CAI. No FI and no track time. Any advice? Anything else I should look into doing while doing the cam swap?
Old Mar 14, 2021 | 04:50 PM
rrwirsi's Avatar
rrwirsi
I replaced mine with a ATI Superdamper Balancer recommended by my Vette go-to Mechanic based on my use of the C5 (Cruising). He said one benefit of this balancer is that it can be rebuilt. Hopefully, I will not have to do a rebuilt.
Old Mar 14, 2021 | 06:09 PM
Chogan835's Avatar
Chogan835
Ati. Do it nice or do it twice.
Old Mar 14, 2021 | 06:16 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by Chogan835
ATI. Do it nice or do it twice.
Old Mar 14, 2021 | 09:14 PM
TheCrow's Avatar
TheCrow
Also forgot to ask--should I pin it being it is a street car? Can that be done with the motor in the car? If so what kit is recommended?
Old Mar 15, 2021 | 09:22 AM
leadfoot4's Avatar
leadfoot4
I installed an ATI balancer, and used their pinning kit. Yes, it can be done with the engine in the car. I don't remember if you can slip the pinning jig on the crank snout with the front cover of the engine in place, however. I did one of those "while I'm in it this far" deals, and pulled the cover to install an LS2 timing chain, so I had the engine open, and plenty of room to slip the jig in place. If you happen to go that far, be sure to cover the open area of the oil pan, so no debris gets in the pan. I used tin foil, for that.
To LS1 Balancer advice
