Headlight Gear
Old Mar 17, 2021 | 07:30 PM
orca13's Avatar
orca13
Default Headlight Gear
Question of the day, if your changing the plastic gear with a brass one, should you change both sides ?? should I buy the kit or just the gear??
Old Mar 17, 2021 | 08:05 PM
USAZR1's Avatar
USAZR1
Please post this in C5 Tech, where it belongs. Thanks
Old Mar 17, 2021 | 10:04 PM
jim993's Avatar
jim993
I did both 11 years ago, still happy with the results. If you do one, the other goes quickly.
Old Mar 17, 2021 | 10:07 PM
jim993's Avatar
jim993
Get the kit, it helps.
Old Mar 17, 2021 | 10:09 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
If you're doing it, I'd get the kit. Would I tear into both at once? No - because I'm pretty lazy. If it ain't broke, don't fix it.
I bought a new motor instead and just did the one side that failed tonight. If it fails, I'll go brass. If it lasts 20 years, then I saved a bunch of time.
Old Mar 18, 2021 | 01:50 AM
I would get the kit - up to you if you want to do both while you are at it or wait until the other one decides to go bad.
And moved to C5 Tech.
Old Mar 18, 2021 | 07:52 AM
Simtech's Avatar
Simtech
I'm cheap so I just rotated the gear 180 degrees, put it back together and went on with life. I figured if I get another 15 years out of the other half of the gear it was time well spent. I don't remember how long ago this was but it has been at least 5 years maybe more.
Old Mar 18, 2021 | 07:53 AM
Stingroo's Avatar
Stingroo
Amen to that. Plenty of other things to spend money on with these cars. lol
Old Mar 18, 2021 | 08:50 AM
Adwest52's Avatar
Adwest52
2021 C5 of the Year Finalist - Unmodified
I like your thinking, especially those of us who rarely drive the car at night and actually use the headlights. Hell, mine may never need to be replaced or rotated.
Old Mar 18, 2021 | 09:10 AM
Simtech's Avatar
Simtech
Mine is a daily driver and I work rotating shifts so they get used all the time. I did turn off the auto headlights so they don't pop up every time I start it in the garage and then go down when I back out.
Old Mar 19, 2021 | 07:11 PM
Ed Ramberger's Avatar
Ed Ramberger
They both have the same wear. I did one side only to have the other fail within 2 months. Order the Rodney Dickman kit for both sides. I wound up paying double postage buying only one. Lesson Learned.
To Headlight Gear
