Code c1232
Old Mar 25, 2021 | 08:46 PM
Travis Franklin's Avatar
Travis Franklin
5th Gear
Default Code c1232
This is the ABS and traction control service code. I had new rims, tires and wheel sensor installed. Haven’t driving it since installed. Can this or will this cause this code?
Old Mar 25, 2021 | 09:14 PM
Smoken1's Avatar
Smoken1
It could if they damaged the harness that goes down to the sensor
Old Mar 26, 2021 | 12:24 AM
BigGun's Avatar
BigGun
Did mean they installed tire pressure sensors? Speed sensors require replacing the hub. That code is for your left front wheel. First thing to do is pull that wheel and check the connection to the speed sensor. It is almost surely a connection or damaged wire. The sensors themselves rarely fail. Yes, it could have been damaged when replacing the tires.
Old Mar 26, 2021 | 12:37 AM
ariZona06's Avatar
ariZona06
What size wheels and tires did you go with? If you deviated from the factory stagger that may be your problem.
To Code c1232
