Torque Setting for Steering Shaft Bolt?
Old Dec 12, 2002 | 09:27 PM
CapeCodCoupe's Avatar
CapeCodCoupe
Default Torque Setting for Steering Shaft Bolt?
I need the service manual torque setting for the forward bolt on the steering shaft bolt where it joins the steering coupler. I think it is bolt number 24. Anyone got a service manual willing to look this up for me? I removed it to install the driver's side FLP Header. Thanks in advance! :)
Old Dec 12, 2002 | 09:53 PM
alc2001's Avatar
alc2001
Default Re: Torque Setting for Steering Shaft Bolt? (CapeCodCoupe)
Mark,
I think you are refering to the lower coupling retaining bolt on the intermediate steering shaft. It is where the lower clamp slides on to the steering gear shaft. The torque spec is 25 lb ft. Good luck.
Alan :seeya
Old Dec 12, 2002 | 09:56 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Make sure to use loctite, and torque it to 25 ft-lbs (34 N-m)
To Torque Setting for Steering Shaft Bolt?
