Can't remove OEM Shifter
Old Apr 4, 2021 | 06:01 PM
H82GOSLW's Avatar
H82GOSLW
Default Can't remove OEM Shifter
Bought a MGW short throw shifter for my Z06. Took everything apart today following the MGW video and no problems.....until I tried to remove the OEM shifter. Even with all bolts removed shifter plate is not even budging a little, almost like that bottom plate is welded to the tranny. I know I have all the bolts out but can't figure out what's still holding it in place. When the guy in the video removes it, it's almost effortless how it came off. Tried wedging a flathead screw drive underneath and it's not moving. Any suggestions?
Old Apr 4, 2021 | 06:03 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Probably has RTV holding it to the lower box. Prybar should solve it.
Old Apr 10, 2021 | 03:10 AM
vette4fl's Avatar
vette4fl
There is a rubber alignment shoe that fits onto the fin on the bottom of the box. Sometimes they will be siliconed in on both sides.... Make sure the clamp on the shifting rod is loose and try prying it.
Old Apr 10, 2021 | 07:41 PM
H82GOSLW's Avatar
H82GOSLW
Thanks for the suggestion. I have everything back together now since weather has been so good here.....next week looks rainy so I'll try taking everything apart again.
To Can't remove OEM Shifter
