Clutch Fluid Refresh
Old Apr 7, 2021 | 09:23 AM
VETTEC599's Avatar
VETTEC599
Default Clutch Fluid Refresh
I need to completely change the clutch fluid on our 99 FRC. I know that it can be done using the ranger method; however, I know this doesn’t completely remove the old fluid.
I normally do all my basic maintenance; however, old age and arthritis dictate that I have the local dealer dedicated Corvette tech do the change.
What can I reasonably expect to pay?
Old Apr 7, 2021 | 09:27 AM
rjacobs's Avatar
rjacobs
A LOT...
To get to the bleeder the whole driveline has to be pulled.
Not worth it AT ALL.
Just use the ranger method and do the best you can with it. Just my opinion.
Old Apr 7, 2021 | 12:33 PM
MetalMan2's Avatar
MetalMan2
Originally Posted by rjacobs
A LOT...
You can access the factory bleeder on the slave cylinder with removing only the mid pipe, tunnel plate, and preferably the clutch inspection cover. I installed the Katech remote bleeder kit with only these items removed, no need to pull the whole driveline. But for a periodic clutch fluid replacement, the factory bleeder ought to be okay (as much as it would suck).
Old Apr 7, 2021 | 02:43 PM
Jcampbell3031's Avatar
Jcampbell3031
First, I would check to see if you have a remote bleeder. More often than not if your clutch has been replaced you have one, even if the shop didn’t tell you they installed it.
Second, if you don’t have a remote bleeder, I would recommend taking the car to an independent corvette shop or even have a friend do it. While yes, it’s more work, the driveline does not need to be taken out. Just the cover taken off. Dealers will charge a lot for this relatively easy task of just taking out bolts.
I 100% agree with you that the ranger method is terrible. The only way to see results is to properly bleed. In fact, I would also recommend putting in a new master cylinder and then doing the bleed. The hydraulics in the master break down over time which cause a lot of problems with clutch fluid and ultimately clutch operation.
Old Apr 11, 2021 | 06:58 PM
vetrnz06's Avatar
vetrnz06
MetalMan2 , question for you. When i get to the slave unit to bleed it and find it is leaking and needs to be replaced can it be done then or does the drivetrain need to be shifted rearward for more clearance? thanx
Old Apr 11, 2021 | 07:41 PM
MetalMan2's Avatar
MetalMan2
If the slave itself happens to be leaking, the whole drivetrain pretty much needs to come out. The slave has to slide over the torque tube's input shaft, which means the torque tube needs to slide back something like 8 inches. At that point the torque tube is effectively ready for removal anyways since everything has to be detached (including wire harnesses).
Once the bell housing inspection cover is removed, you'll be able to see the status of the slave cylinder. I don't think it's particularly likely that it will be leaking.
Old Apr 12, 2021 | 01:03 AM
vette4fl's Avatar
vette4fl
I had a local shop replace the clutch master cylinder and they managed to change the fluid. Cost about $500 including a genuine GM master cylinder.
Old Apr 12, 2021 | 09:18 PM
strand rider's Avatar
strand rider
NAPA auto on the web has a service cost estimator on the website. .
I don't know how detailed it is, I just happened to stumble across it yesterday. Out of curiosity, I looked up replacing the harmonic balancer on a c5, and it gave about an $800 labor charge, while listing the hours of labor and the parts price separately.
Site says it is an estimate only and to contact your local Napa garage for details. Since I don't have access to a rate book, this seemed like a good way to guesstimate the ballpark figures, or time, of nay projected repair plans. . The labor cost results seemed a little low for my area, nobody likes to scare off customers, but then my area doesn't have any NAPA garages,
I assume the labor hours needed are generated from the usual reliable tables, what else, since any fiction would cause more trouble than any possible value
Old Apr 13, 2021 | 10:59 AM
Budwise's Avatar
Budwise
You can access the bleeder from the top if you remove the intake manifold and lay over the top of the engine with some extensions. I've done it. MUCH easier than dropping everything from below.
To Clutch Fluid Refresh
