Squeaking from belt drive
Old Apr 7, 2021 | 07:24 PM
hEllberg's Avatar
hEllberg
Default Squeaking from belt drive
Hello!
For the last year I've had my fair share of squeaks from the belt drive in my 98 C5. It first started with the tensioner pulley bearing being shot, so I replaced that, problem solved. I then had a problem with the serpentine belt squeaking, replaced that and another problem solved. Then later on my AC tensioner pulley bearing was all dry. I packed this bearing with grease and that also fixed my problem. Also just a couple of weeks after that I got a squeak in the AC belt....... Replaced that and OK again.......
Now after 3 weeks of driving after having the car stored over winter I got a new squeak. I saw my main drive belt tensioner wobbling quite alot actually, then I replaced the tensioner and I still have the squeak. Now I did drive for some hours with the squeak because I was quite far away from home. So this time I'm thinking the serpentine belt I installed last summer, is bad because my tensioner has been out of alignment and have been wobbling, thus putting alot of strain on the belt. Does this sound like a good theory? My AC belt isn't even on at the moment so it can't be anything related to the AC drive.
Spraying water on the serpentine belt on either side makes the squeaking go away, I went over every god **** pulley making sure they are good. What do you think, should I try to pick up another belt and see? They do cost quite abit since I live in Norway. I have ordered some gatorback belts, but they won't arrive in like 1 month or so, and I have a shop nearby selling standard replacement belts for american cars.
Old Apr 7, 2021 | 07:56 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Old Apr 7, 2021 | 08:33 PM
Smoken1's Avatar
Smoken1
If your pulley system is all ok I would try the Continental Elite serpentine belts
Old Apr 7, 2021 | 09:32 PM
hEllberg's Avatar
hEllberg
I have ordered them already, but the wait is about 1 month, so im picking up a normal dayco belt untill that comes, a local shop can get me one on the day.
Old Apr 9, 2021 | 08:28 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by hEllberg
Hello!
Here's your problem>>>you used God's name in vain...
Old Apr 9, 2021 | 10:29 AM
grinder11's Avatar
grinder11
Originally Posted by Yello95
Here's your problem>>>you used God's name in vane...
Vain.......😁
Old Apr 9, 2021 | 02:20 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Vain.......😁
was talkin bout an artery...
Old Apr 10, 2021 | 07:15 PM
hEllberg's Avatar
hEllberg
Solved the issue, was once again the serpentine belt being bad, probably caused by the failing tensioner.
Old Apr 12, 2021 | 03:02 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
So lets see how long the solved problem lasts. Around 1000 miles for me...I had the same problem and finally replaced the balancer...
To Squeaking from belt drive
