Front breaks lock
Old Apr 11, 2021 | 07:41 PM
sultan 2 ZR1 KSA's Avatar
sultan 2 ZR1 KSA
Default Front breaks lock
Hi all it’s
I did my search 🔦 looked up all the forums and threads with no luck
It’s been a while that I have been fitting gremlins in my C5 Z06 2002 abs system , changed the ABS module and did a full check on all wiring found a kinked wire , had some codes on the Dash for the TC and ABS , now not codes so wiring problems solved.
so now as the title says and as I am under hard braking or emergency stops my front breaks lock up then the ABS informes me that it’s active !!!! But I don’t feel the ABS working
can some one shed some light or help direct me to what I should do next
thanks in advance
Old Apr 12, 2021 | 09:37 PM
hotfrank's Avatar
hotfrank
Usually locking brakes relates to blocked brake lines or caliper.
Old Apr 13, 2021 | 07:54 PM
k24556's Avatar
k24556
So how full is your master cyl reservoir? If it is at the very top and you use the brakes, heat will expand the fluid and with no head space the only way the pressure goes is to lock the calipers. I never fill above the seam. the min is below the seam the max just above. This is embossed in the side of the reservoir but hard to see.
Old Apr 13, 2021 | 10:57 PM
lionelhutz's Avatar
lionelhutz
I HIGHLY doubt the plastic reservoir can hold enough pressure to lock the front brakes.
Are you sure the ABS doesn't come on? Are you doing this during wet or dry conditions?
Old Apr 13, 2021 | 11:25 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
Are both sides brakes locking up or one side?
Old Apr 14, 2021 | 06:26 AM
k24556's Avatar
k24556
overfilling is a very common mistake for novices on the track. That's one of the big things we tech before letting them out for an HPDE event. It can and will smoke the front brakes. All 4 for that matter, but there is more effect on the front.
To Front breaks lock
