P0107 Code After Atomic MSD Intake Intake Install
First I have a 99 corvette 5.7 with ported stage 2 Tsp heads
running about 10.8 cr with a 227/234 .600 cam
Upgraded my ls6 intake to the atomic msd and a nick williams 103mm dbw
Second, I'm getting the p0107 code
I have replaced the MAP with ac delco brand
After removing the intake like 8x literally trying to resolve this issue
I finally extended map sensor wires so i could mount the map sensor at the front of the intake
Next I have tested the plug am getting the .5v on org/blk wire
There green wire
Then gray faded wire
However when i perform a continuity test it buzz between the gray/orange wire
I'm thinking the gray and green wire is flip because if the gray wire is ground does it need to be in the middle?
Or could it be the computer?
I'm stlll trying to locate the MAP wires at the "end of the hardness " which I think you mean at the PCM connector,
He is were I am. At the plug Im getting .5v on the orange/blk, 5.06 v on the grey and .05 on the green signal wire with key on engine off. It seem at one point a got a 4.5v reading on the signal wire but after double triple checking I only getting the .05 v. I'm not sure if I'm right but his is what happen. I have stripped back the harness and resoldered the signal wire but still getting the .05 volts. I plan today is to open the fender well can check/clean the connections. I have a downloaded a wiring diagram i just need to figure out which pins are which. Thank for any additional input you give.
