DIY clutch install questions
Old Dec 13, 2002 | 11:40 AM
Pep's Avatar
Pep
Default DIY clutch install questions
I am planning a clutch install over the holidays and wanted to hear from some of the DIYers.
I am installing:
Ram 402/6130
McLeod adj master
Z06 slave GM 12562767
synthetic trans/hyd fluid
Have I forgotten any parts? Any TTY bolts to be replaced?
Is that the right slave? I keep finding shops that advertise the '288 as the '02 Z06 slave.
I have an extra flywheel that I would like to have surfaced and balanced with the clutch. Any recommendations in DFW area? Prefer FW.
Will jack stands provide enough clearance to remove the trans/diff?
TIA for suggestions.
Old Dec 13, 2002 | 05:45 PM
scool93535's Avatar
scool93535
Default Re: DIY clutch install questions (Pep)
Let's keep in touch, I'll be replacing my clutch in about 2 weeks.
Do a search in the CF archives, slow search look into the text, for "clutch replacement" or "replacing clutch". I found several items and "gottcha" warrnings there.
LOL
:cheers:
Old Dec 13, 2002 | 06:00 PM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: DIY clutch install questions (scool93535)
If you try to do that job on jack stands you better have at least three people with you. The rear carrier/tranny and torque tube is quite awkward as a unit. You have to be very careful with the installation as it is very easy to damage the pilot bearing. If this gets damaged you could experience shifting problems. For the $300-400 that it cost it may be worth having someone else do it or find someone with a lift. I'm not saying it's impossible but a real bitch on your back! If you have any other questions you can drop me a E-mail as I have done quite a few.
Old Dec 13, 2002 | 10:55 PM
Pep's Avatar
Pep
scool,
Will do. I plan on starting next weekend.
I have read up on most of the common mistakes. The lazy pedal problem is the only thing I saw with no difinative answer.
9D9,
Yeah, I have a few extra backs I can break. As far as having it installed, I enjoy the work too much to pay someone. Masochistic I guess.
Is it possible to install the tube/trans/diff separately? That does look like an awkward assy to align.
How about the slave PN? I have seen the '02 listed as 12562767 and 15046288.
Oh yeah, I found a shop to surface the flywheel and balance with the clutch. They also offered to lighten the flywheel by a couple of lbs. Anyone tried this?
Old Dec 13, 2002 | 11:11 PM
scool93535's Avatar
scool93535
The shop manual says to NOT resurface, replace. Maybe somebody's tried it and it worked but, you're on your own. I'd go with AL if you want lighter.
I probably won't start until the first weekend after the new year.
The lazy pedal problem sounds like the GM restriction in the line between the master & slave.
Keep us posted. LOL
:cheers:
To DIY clutch install questions
