HELP!! car throwing tons of codes, other electrical issues
Chasing down some inevitable issues, but could use some thoughts on a few:
* the passenger window intermittently stops working.. by intermittently, I mean it won't work for a while, then for whatever reason. start working. doesn't seem to matter if I'm running over bumps, jar the door, whatever.. can't seem to attribute a cause to this. obviously the fuse isn't dead.. I pulled the door panel, checked the window switch , the electrical connections are fine... thoughts? bad window switch?
* as I was working on my headunit, with the ignition in accessory mode, all of a sudden i get a slew of errors on the DIC -- reduced engine power, service traction control, service tire pressure sensors, all at the same time... thoughts? On;ly thing I can think of is that right before running the car today, I had a slightly dead battery (clicked, wasn't stone dead)... I had a spare yellow top hanging around (don't we all?) so I replaced it .. so maybe the computer hasn't fully gone through it's learning cycle? I'll note that these errors popped up AFTER driving it for an hour.. through town, on i95, AND popped up which the engine off.. Again, thougnbts?
*blinker -- neither of the directionals are working... I really don't feel like spending hours trouble shooting this... anyone know what fuse/relay this is? any thoughts?
Thanks!!
If the battery is known to be fully charged and the window issue is still there, since you’ve checked the connections, it may well be the switch.
I hope you remembered to connect your hazard switch when putting the dash in.
Thanks!!
First off see what DTC’s (codes) are set...if you have a bunch of U codes (communication) you may have a serial data network issue...a lot of times these are caused by aftermarket radios systems...these may sometimes cause your car to shutoff !!..the PCM really doesn’t go through a “learning cycle”...the only thing that may come close is an idle relearn after the battery is disconnected...as far as the possible COMM codes I’d disconnect your audio system and see what happens !!...the windows not working can also be caused by these COMM codes.
Weird thing is that the car ran fine when I drove it from the shop to my house ( ten minites) and then after I swapped the battery with a fresh one, it drove fine for a hour long drive from New York to ct. The codes started getting thrown literally while the car was in my.garage, not running, with the ignition set to acc.
I pulled the code, there are codes for practically every system (abs, traction, gauges, radio no comm, etc) I'm assuming at this point this is a CAN issue... an area I have little experience trouble shooting. ...
Yes, you’ll see the fuel gauge go to E, the water temp maxes out, you’ll get all the DIC warnings, windows don’t work !!...we’ve see a few of these here the last few months...not hard to troubleshoot... just an understanding of the Class 2 serial data network...since retiring and moving to Florida I’ve been meaning to do a YouTube video on diagnosing this problem...this may just be the time !!...ok, so disconnect that audio system and if it doesn’t work we can check a few other things...the single wire data network is how all the modules communicate with one another...simple computer language...zeroes and ones !!...all of the cars modules have this single wire which come together at 2 splice packs which are located next to the BCM...if power or ground finds its way onto this data wire ALL hell breaks loose...at the splice pack you’ll be looking for a power or ground that’s not supposed to be there !!...video below !!
I'm betting its the dammed interface I used when installing the radio ... thieves stole my headunit last week, and even took the PAC OEM Vet interface-- everything worked fine with that. But when I purchased replacement headunit/amps from crutchfield, I used their interface (forgot which one, it's a brand name). That's the *only* thing different in the electrical system .. I'd bet money it's the issue... hopefully ...
Malfunction in electrical circuits can also bring about problems with the locking and unlocking of the doors by the key fob. It can also affect the music system of the car. It can be seen as a change in the source of the music, from the CD player to the radio, or through the auto-tuning of radio frequencies. The resetting of the clock on the radio every time after the engine is switched on, is also a sign of the failure of the body control module.
I swapped out the garbage interface from cruthfield, swapped in a PAC. I haven't taken the car for a drive since that, but I haven't yet gotten the pages and pages of "serial line" errors for every single system... here's where I stand, any thoughts?
*I've cycle the car through several ignition sequences. On the latest sequence, no codes except the following:
* a6-scm No Comm (c7 seats, so, no seat control module)
*a1 - RDCM No Comm
* A0 - LDCM u1064 h (loss of communication with BCM)
*99- HVAC b0361 h (this is a new one, first time it's popped up, and since gone.. apparently actuator short to ground?)
* 99 HVAC b0338 (no temp sensor, known issue, have to replace it)
*80 - Radio NO Comm (to be expected, after market radio?)
the passenger window still does not work... the door lock worked intermittently last night, but not today. The car otherwise runs fine. Driver side door/locks work fine.
I have a new passenger door panel switch (unlikely, I pulled it, looks fine) and ordered a lock/window control module for the passenger door.
Anything else I can look into?
*a1 - RDCM No Comm
Did you clear all the codes and then turn key off and back on and then try to read codes and see if they come back as C codes or current ??....so you don’t even have a DVOM ??...it would be a good idea to at least check the data wire for 12 volts or ground on it. So basically all we have are no comms for both door modules and the air bag module ??...do you know where both splice packs (star connectors) are to the left of the BCM ??...there is a shorting bar on each one...you can pop off each one and clean it with emery cloth or sandpaper and pop it back on...if there is oxidation on those shorting bars you may get no comms to those modules !!
Anyway, I found the problem -- others have had exactly the same issue as I have ... apparently there's connector to the RDCM that runs through the rubber grommet to the door... that somehow is lose/grounding out. It will at least cause the RDCM No COMM error, and the passenger window/door lock to stop working, and others have reported the other issue I've been having, where every system goes to "no comm" and "reduced engine power" pops up.
Got my hand back there, jiggled it around, and everything came back on. Only error codes are the ones I would expect, RDCM wend from no comm to No Codes.
That'll get me home, when I get there I'll disassemble and take a look.
Thanks for all the help! Hopefully this is it...
I'm out on long island, zip is my work zip.
I'm hoping that loose connection really is really it .. it's working now, I'll button everything up and hopefully it stays together for the ride home. I really just don't want to take it apart here, the garage I have here is just that.. a garage. It's a beach house, so not a ton of attention was paid to the garage. Lighting sucks, limited space.. no heat, no a/c :-) Though the view of the water is nice.
