Question on clutch install
Old Apr 20, 2021 | 08:07 AM
Silverwolf_pup's Avatar
Silverwolf_pup
Default Question on clutch install
I have a question on my gap numbers between the clutch and slave cylinder, it’s a monster stage 2 single disk with new slave cylinder.
So here is my two final numbers I got from my measurements, clutch 2.4863 inches, slave cylinder 2.2356 inches.
Will this be in spec where I won’t have problems, and don’t have to shim? Please help and thanks
Old Apr 20, 2021 | 11:43 AM
ss2z06's Avatar
ss2z06
Typically with the new clutch there should be a sheet with what kind of specs are acceptable along with how and where to take the measurements. If you don't have it here is the link:
http://shop.monsterclutches.com/pres...easurement.jpg
I don't know where/how you took your measurements but you can reference this and will know the answer.
Old Apr 21, 2021 | 06:54 AM
Silverwolf_pup
Monster did provide a sheet like this, but it didn’t really tell me anything like tolerating references, but I still don’t know if my numbers are acceptable with the gap.
Old Apr 21, 2021 | 01:43 PM
ss2z06's Avatar
ss2z06
If I recall they like to see no less than a .0625" and no more than a .200" gap. My suggestion would be to call or email to confirm.
Old Apr 21, 2021 | 05:00 PM
Silverwolf_pup
Yeah I will contact them, I am so confused with this, thanks for help
Old Apr 22, 2021 | 02:30 PM
MatsA's Avatar
MatsA
2024 C6 of the Year Finalist - Modified
I had 0.18 measured gap on my Monster 2 disc clutch and it works perfect so far , just some 70 miles on it.
To Question on clutch install
