F45 Removal
Old Apr 20, 2021 | 05:08 PM
77BlueL82's Avatar
77BlueL82
Default F45 Removal
I'm swapping out my F45 shocks for 2013 Z06 shocks on my 97. When I install the shock simulator, does the light blue wire in the ESU have to be removed? Thanks in advance for any help.
Old Apr 20, 2021 | 07:14 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I think it takes a TECH II when doing a F45 shock swap
Old Apr 20, 2021 | 07:21 PM
77BlueL82's Avatar
77BlueL82
The instructions for the simulators mentioned cutting the wire and I'm hoping someone can shed some light on that procedure. I don't like cutting wires. Thanks.
Old Apr 20, 2021 | 07:56 PM
Smoken1's Avatar
Smoken1
When I added the resistors I didn't cut any wires.. Post the instructions
Old Apr 20, 2021 | 09:59 PM
77BlueL82's Avatar
77BlueL82
Here is the link to the instructions.........https://www.zip-corvette.com/amfile/...product/10987/
Old Apr 21, 2021 | 12:03 AM
Smoken1's Avatar
Smoken1
Try using the 4 connectors that have 2 pins in them and not cut any wires
Old Apr 21, 2021 | 03:38 AM
77BlueL82's Avatar
77BlueL82
Default F45 Shocks
Just read on another post that the directions ar wrong. The light blue wire should only be cut on the 2003. It would be nice if the instructions were corrected. Thanks to all for your help.
Old Apr 21, 2021 | 11:11 AM
CMC76's Avatar
CMC76
I just had my f45 tuned out a few weeks ago on my 99.
normally takes 10 minutes, mine took an hour due to some communication errors
Old Apr 21, 2021 | 01:10 PM
77BlueL82's Avatar
77BlueL82
I'm having a friend, who did his, do mine.
Old Apr 22, 2021 | 11:11 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Just read on another post that the directions are wrong. The light blue wire should only be cut on the 2003. It would be nice if the instructions were corrected. Thanks to all for your help.
I'm a much better "mechanic", than I am an "electrician", but given even my limited electrical experience, I would tend to think that the purpose of those "simulators" is to take the place of the electronics of the actual F45 shock absorber. Therefore using the simulator shouldn't require cutting anything.....
Old Apr 22, 2021 | 11:07 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
There sims seem the cheapest and easiest way to go.
Old Apr 22, 2021 | 11:14 PM
SilverC54me's Avatar
SilverC54me
Find a shop with a Tech2 and have them remove the option.
To F45 Removal
