Gonna be getting one and need to know where I can get all the plumbing
connections and lines for the best/easiest install?
Any help would be greatly appreciated :yesnod:
TIA
I love my line lock..Mike Norris installed it for me.. :yesnod: You will need to buty the install kit and your local chevy dealer will also have some of the pressure lines too..From what Mike told me it's a PIA job..it takes alot of patience ..take your time and check for leaks before you drive off..Enjoy!
I'm not too sure that there is a "kit". Although there could be by now. You may just have to go to a parts store and figure out the fittings needed. A "standard" Hurst line-loc is machined for double flared lines. The GM lines are bubble flare lines. You might consider getting a new GM line from someone like Fitchner Chevrolet and then cutting it as needed so that you keep the bubble flares on the GM side of the lines. You can then add double flares on the line-loc ends of the brake line with new double flare fittings attached. If you are careful enough not to get air into the abs, you might even get by just bleeding from the abs back to the master cyl.
Mike
Thanks Mike...
That's the kind of info I was looking for :thumbs:
I'll do some research here and see what I can come up with for the connections..
Thanks again! :cheers:
I found all the necessary braided line and ISO fittings necessary to get mine done myself at a local Hose Supply House, you should definitley have something like that up your way :) :cheers:
Thanks Mean Green...Those braided lines and ISO fittings like you used are what I'm interested in...you got any specs you can share with me so I get the right ones?...TIA :thumbs: :cheers:
