Seat control module
So has anyone ever repair one? Everything works on it but the back lift. It will go only one direction up and not switch to down. It is not any mechaincal issue as I removed the motor from bracket and it still goes only one direction. So I assume a relay went bad in module.
https://www.corvetteforum.com/forums...e-for-fix.html
but sometimes it will not go forward. If I jiggle the electrical connector from
the seat to the floor, it starts working. I have a bad connection in that connector
but still need to dig in to it.
