So I was working on upgrading to dual springs for a cam sway and found one valve woth thr stem worn down pretty good. Obviously this is very concerning and I know what would happen if it be ded up breaking because of the increased spring pressure so questions is what caused it to wear like this...bad valve stem, bad lifter, etc.? The first photo is with springs install on each side of the damaged one to compare. TIA
Just a guess, but I'm guessing a mistake was made in heat treating, either the rocker arm, the valve stem, or BOTH. I've never seen a bad rocker, so I'm leaning towards a bad valve stem. Are these OEM valves? OEM rockers? At least you caught it pretty early. The only way a lifter could be involved would be that it somehow got plugged up, and no oil was flowing up the pushrod to the rocker. Check the pushrod cup, the end where the pushrod fits into the rocker. Sorry you're having this problem. But it should be a somewhat easy fix. Good luck, and please post up what happened when you know what caused this......
Yep that's my spring compressor tool sorry guys should've removed that before taking pics and replacing the valve or entire heads is what is thinking too unfortunately
