PCV Question
Old May 1, 2021 | 10:14 PM
TheCrow's Avatar
TheCrow
Default PCV Question
OK Guys--I am finishing up with my upgrade but have a small issue to resolve. Have a 99 FRC LS1. Did several upgrades including an intake and LS2 throttle body. The original TB had a hose attached to the passenger side valve cover. The LS2 throttle body does not have this. The other parts of the PCV system are installed properly. Do I need to just block this port on the valve cover?
Old May 2, 2021 | 12:26 AM
Moved to C5 Tech.
Old May 2, 2021 | 11:22 AM
Javybaez's Avatar
Javybaez
Why would you think to just block it off? That port is necessary to get fresh air into the crankcase which is how the LS1 is designed. You may want to look at an LS2 motor and see where the line goes in that motor design.
Old May 2, 2021 | 12:09 PM
Javybaez's Avatar
Javybaez
Gotta drill into the coupler and run the line.
Old May 2, 2021 | 10:28 PM
TheCrow's Avatar
TheCrow
Roger that. Thank you
To PCV Question
