C5R heads in a normal LS1/LS6 engine... It is possible??
Old Dec 14, 2002 | 01:21 PM
Greenbeast's Avatar
Greenbeast
Default C5R heads in a normal LS1/LS6 engine... It is possible??
I know that in the past, it is too much job and money....
Now with more than 5 years of development, would like to know if it possible to switch the LS1/LS6 heads for the C5R heads!!
Also what intake is the best to use in conjuntion with the C5R heads!
I'm planning to do a conversion in the '99 FRC soon and just finding the best combo!!
Any input would be fine, thanks!!
Old Dec 14, 2002 | 01:34 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: C5R heads in a normal LS1/LS6 engine... It is possible?? (Greenbeast)
From what I understand they will work on a 4.125" bore(not sure if it has to be the C5-R block), but you will definately need a custom intake made. Not sure what headers will fit either. If you have the money for the heads, then you should be ok with the rest! ;)
Old Dec 14, 2002 | 01:43 PM
Greenbeast's Avatar
Greenbeast
Default Re: C5R heads in a normal LS1/LS6 engine... It is possible?? (C5-VERT)
How much they cost??
And where to buy it??
Thanks!!
Old Dec 14, 2002 | 04:50 PM
SLED28's Avatar
SLED28
St. Jude Donor "08
I have a set of C5R heads that are almost done. They are flowing 377/250 in/ex on our Superflow 600 bench. With an exhaust pipe, it is 20-25cfm more. This is a drag race port job.
Please give us a call for details toll free at 866-539-5605 and ask for Wade.
Thanks,
Dave DiLuca http://www.agostino-racing.com
Old Dec 14, 2002 | 09:11 PM
johnnyC5's Avatar
johnnyC5
get a hold of Wade at Agostino Racing Engines, im sure he would be able to assist you on whether or not it can be done.
sh'it, would help if i scrolled down to read the posts.... looks like SLED28 has the answer for you
[Modified by johnnyC5, 12:14 AM 12/15/2002]
Old Dec 17, 2002 | 08:12 AM
Greenbeast's Avatar
Greenbeast
Default Re: C5R heads in a normal LS1/LS6 engine... It is possible?? (SLED28)
When you mean drag race, it is not for street??
Thanks!!
Old Dec 17, 2002 | 08:22 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
I'd assume he meant they were ported for making tons of power at higher RPM such as you need for dragracing. A huge cammed solid roller setup would be a necessity for these heads.
To C5R heads in a normal LS1/LS6 engine... It is possible??
