Turn Signal Conversion to LEDs
Old May 5, 2021 | 01:28 PM
Silverone1's Avatar
Silverone1
Default Turn Signal Conversion to LEDs
Changed my signal lens in C5 from stock to clear and changed stock bulb to LEDs and added a Hyperflash Harness.
DRL light Amber (check). DRLs run white with fog lights are on (check). Front & Back Turn signals work (check).
Issue: Front turn signals (amber) are very weak when Headlights are turned on? Question is it the bulb? Or is it a connection?
Looking for help thanks in advance.
Old May 8, 2021 | 05:44 PM
link9a's Avatar
link9a
Switch your bulb led and see if still the same problem if yes that's mean there's a problem with the voltage it's doesn't accept that kind of LED... let us know...
