Hatch wont pop button fob and door doesnt work
Old May 9, 2021 | 10:06 PM
DirtyDee's Avatar
DirtyDee
2nd Gear
Default Hatch wont pop button fob and door doesnt work
Ive been trying my best to track this down , hatch will only pop if i jumper the relay side. Button doesnt work,fob wont do it, neither will the door key . Iv rigged strings for now but
want to resolve this . At the switch i get 12v on orange ,4.4v on org/blk when pressing fog button , and nothing on the yellow wire . I Get 3.2 v on the blk wire the rest i get no voltage. From what i understand that yellow wire should get power.
i also cant get any voltage at fuse number 26 which is the hatch fuse , the fuse is fine but no voltage
Relay is good swapped with known good relay .
I have opened bcm and inspected all solders amd didnt find anything , also no other electronics are malfunctioning in this car just the hatch wont pop . I have also checked numerous ground all coming up really really clean
Hatch hasnt worked aince i bought the car
Any insight is welcomed
