My Plug Wire Keeps Popping Off....!!
Old Dec 14, 2002 | 09:48 PM
GmasterB's Avatar
GmasterB
Default My Plug Wire Keeps Popping Off....!!
The first spark plug wire on the drivers side, near the altenator, keeps popping off ever since I installed my headers. I know the headers don't have anything to do with it, but that was the first time I removed any of the wires. Anyway, a day or so after the header install, my car is running crappy and missing. I check the plug wires, sure enough that plug wire is not "all" the way on. So I snap it in place and go about my business. Well today I'm driving to work (about 1.5 weeks after the 1st incident) and my car starts running crappy. Check that plug wire, sure enough it's just barely on there :mad .
So anyone know what the deal is? Is it time for some new wires? These are the stock wires, with about 28k miles on my car. With my luck, I'll be racing someone and the damn wire will come loose and I'll lose :cuss
Old Dec 14, 2002 | 10:36 PM
Crushinator's Avatar
Crushinator
Default Re: My Plug Wire Keeps Popping Off....!! (GmasterB)
You got it! Get a set of MSD's. You'll be a happy man! :cheers:
Old Dec 14, 2002 | 11:12 PM
wickedvette's Avatar
wickedvette
Cruise-In II Veteran
Cruise-In III Veteran
Sounds like the "spring" metal inside the boot has lost it's ability to grab the plug end.....time for a new wire. :yesnod:
Old Dec 15, 2002 | 10:06 AM
Oldvetter's Avatar
Oldvetter
Default Re: My Plug Wire Keeps Popping Off....!! (wickedvette)
You can squeeze the connector with a pliers to get it to hold. Have done to other cars.
Old Dec 15, 2002 | 03:55 PM
GmasterB's Avatar
GmasterB
Default Re: My Plug Wire Keeps Popping Off....!! (Oldvetter)
Thanks for the tip, I'll go give that a try. I really didn't want to spend any money on the vette this month, I need to buy other people stuff for once....lol
Old Dec 15, 2002 | 06:12 PM
blktie8's Avatar
blktie8
Check that the plug is tight or maybe cracked and leaking if that isn't it
call Steve and get a set of Magnecor wires with the angle boots.
You'll not be sorry.
Old Dec 15, 2002 | 07:23 PM
GmasterB's Avatar
GmasterB
Default Re: My Plug Wire Keeps Popping Off....!! (blktie8)
Well, it runs fine when the plug wire is on all the way, so that led me to believe nothing is wrong with the plug. But as a precaution, I'll go out and remove that plug real quick and check it out. I'm also going to get out the ol' pliers and see if I can't fix that plug wire. Christmas is just too close to buy my self stuff.
Old Dec 15, 2002 | 08:29 PM
Gary2KC5's Avatar
Gary2KC5
I've had one of my MSD wires come loose before. Magnecor wires are angled wires? Sounds like Magnecor wires are made for engines with headers.
I will considers those after I've burnt up all my spare (after you burn 1 you get a second set for spares) MSD wires.
Old Dec 15, 2002 | 08:35 PM
luvinc5's Avatar
luvinc5
Default Re: My Plug Wire Keeps Popping Off....!! (Gary2KC5)
I'm using Magnecor 8.5kv wires and they are great. They use oem connectors so you can use the factory heat shields.
To My Plug Wire Keeps Popping Off....!!
