C5 Under dash repair/replace recommendations
Old May 10, 2021 | 05:15 PM
arandle007's Avatar
arandle007
3rd Gear
Default C5 Under dash repair/replace recommendations
I took my C5 to the dealer (not the best idea) with A/C issues and HUD issues.
Quote for A/C was $1400 to replace the Actuator on the drivers side. Part was to be $250 for 1. Rest was to be for labor. Then when speaking with them, they recommended replacing all "4" actuators (I have yet to find 4 documented anywhere). After coming to this forum, found that I could get the actuator elsewhere for less and had plenty of recommendations (THANK YOU Corvette Forum). Then I looked and found that there are 2 actuators, 1 per side, so I ordered both and now have them.
For the HUD fix. I know that the issue is the broken pin (again, thanks to CF) since I can look through the windshield and see it on. Just that the mirror is down. Dealer quoted $1900 to fix. When I told them that the part to repair was $20, they said that they don't repair and that the quote is to replace with used unit only. Ordered $20 part and will follow the excellent instructions provided in this forum on how to fix it myself.
Now the real question I have is, since I will have the dash out, what else should I replace while at that stage so that I am ready for another 20 years of the awesome car?
Thank you all for great insight. I have been looking through the forum and unable to find anything to answer this question.
Old May 10, 2021 | 07:45 PM
rjacobs's Avatar
rjacobs
what part did you order to repair the HUD? I just used a small screw in place of the pivot pin that was broken off...
Old May 11, 2021 | 01:31 PM
arandle007's Avatar
arandle007
3rd Gear
1997-2004 C5 CORVETTE HEADS UP DISPLAY HUD REPAIR KIT | eBay
Replaces the side piece with PIN and adds the bushing on the other side.
Old May 11, 2021 | 03:28 PM
rjacobs's Avatar
rjacobs
nice. looks like somebody is 3d printing them. Wish I had known about that 3 or 4 months ago when I took mine out to fix it.
To C5 Under dash repair/replace recommendations
