Throttle body
Old May 15, 2021 | 01:03 PM
BGraves's Avatar
BGraves
5th Gear
Default Throttle body
I put a used ls2 throttle body on my c5 corvette now I have the coda P2101 and P2135 is there a way to fit it because my car is one limp mode
Old May 15, 2021 | 01:59 PM
Moved to C5 Tech.
Old May 15, 2021 | 02:30 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
The TPS to TAC Module appears to be wired differently on the LS2 TB !!...hope this helps !!
Old May 15, 2021 | 04:53 PM
miami993c297's Avatar
miami993c297
Is the blade on your TB Silver or Gold color?
Old May 15, 2021 | 11:14 PM
BGraves's Avatar
BGraves
5th Gear
it is gold
Old May 16, 2021 | 08:33 AM
miami993c297
it is gold
Make research about LS2 90mm TB on C5...because your chances to have a LS2 Gold Blade TB working are pretty much down to zero...you need a LS2 90mm Silver Blade TB to have compatibility with the C5 electronic.
Old May 16, 2021 | 11:07 AM
grinder11's Avatar
grinder11
Not to hijack, but is the gold blade a 3 bolt design? Whatever TB has the 3 bolt design, I used on my early Wison/FAST cathedral port intake, and had no issues. This was in 2005......
Old May 16, 2021 | 12:25 PM
dskinsler83's Avatar
dskinsler83
Same guy on IG that is on #3
To Throttle body
