C5 Brake Caliper Measurements
Old May 18, 2021 | 06:11 PM
Chev72lle's Avatar
Chev72lle
3rd Gear
Default C5 Brake Caliper Measurements
Hey Guys I'm Hoping That Someone Can Help Me Out With This Issue I'm Having.
I'm Building A 72 Malibu/Chevelle & I'm Putting Corvette C5 Brakes All Around. The Manufacture Of The Particular Wheel I Am Interested In Purchasing Sent Me These Two Diagrams For Me To Fill Out & Send Back So They Can Cut The Wheels To Size. The Problem Is I Have No Idea How To Get The Correct Measurements. Does Anyone Know The Correct Measurements They're Asking For The Stock C5 Calipers?
Thank you guys for any input
Old May 21, 2021 | 10:07 PM
redzg's Avatar
redzg
Are you using a complete C5 brake package, including spindles and rotors? If not, then the dimensions from a C5 won't tell you, or you wheel maker, what you need to know. Do you have the brakes mocked up or mounted on the spindles yet? That's going to be necessary to make the measurements, calculating the dimensions from loose parts might not be close enough.
Interesting the wheel supplier's sketch is for a front wheel drive car -- you might want to ask if he wants you to reverse the sketches for rear wheel drive.
Old May 22, 2021 | 07:06 AM
feeder82's Avatar
feeder82
That won't be the only measurements you need for a custom wheel. Those will get you the clearance for the brakes and hub. What about your fender clearance?
Old May 22, 2021 | 09:44 PM
Chev72lle's Avatar
Chev72lle
3rd Gear
1) Yes, I'm Using A Complete C5 Package (Spindles, Calipers, Rotors & Lines)
2) The Complete Brake Assembly Set Up Is On The Car Mounted.
3) As Far As The Sketch, Its A General Diagram To Let Me Know What Exactly On The Calipers Need To Be Measured In Order For The Wheel Clearance.
Old May 22, 2021 | 09:47 PM
Chev72lle's Avatar
Chev72lle
3rd Gear
That What Your Speaking Of Is The Wheel Offset & Backspacing. We Have Those Measurements Figured Out Already.
Old May 23, 2021 | 08:20 AM
feeder82's Avatar
feeder82
This might help
https://images.app.goo.gl/nr6HmULzRkcbosYBA
To C5 Brake Caliper Measurements
