Is it possible my cat has gone bad?
About 10 days ago a truck was parked blocking half my driveway, so I politely exited to the left, where there's a hump up in the pavement. The very center of my car scraped going over this hump. Looking under the car I see the catalytic converter is what's in the center, and it sticks down about an inch below the rest of the car's body, so I'm thinking that's what hit.
At first not a whole lot happened. On days 3-5 I started hearing a rattling coming from my catalytic converter area at high RPM - to me this is an earmark of a cat going bad. During this time it felt like my car was down pretty dramatic HP.
From about day 5 until yesterday the car has progressively gotten louder and throatier, and it feels like its gained back its HP or is even faster than usual. My car is supercharged so a catalytic converter blowout would likely cause a noticeable difference in HP. The exhaust also smells a lot more fuel-ey and at high-RPM I can sometimes see a trail of gas fumes chu-chuing out the quad exit pipes. There's also a TON of that sexy popping noise our cars sometimes get from the h-pipe, which I absolutely love, but can't help but think it's happening because one of my cats is more blown out than the other, causing a disparity in pressure between the two exhaust tubes.
From these symptoms, do you guys think its possible that my cat's internal honeycomb structure was blown out? Is my cat bad? It seems like I almost literally blew the **** out of the inside of my catalytic converters, clearing up back pressure and increasing HP, but I have no idea if that's actually possible. I want to get some opinions before I have the cat ripped apart. I had it looked at at an exhaust shop and the guy said there's no exhaust leaks and all the plumbing from my headers to my exhaust tips looks 100% fine externally. He didn't even mention a dent from me scraping.
I also ended up with a chunk of the material inside one of my mufflers and had to remove the .
muffler and shake out the chunk
The mallet test would be quick to do too.
